Page 5 of 5 1 2 3 4 5
Re: Street/Strip Car Street Usage [Re: BSB67] #1102650
10/31/11 11:38 AM
10/31/11 11:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Ron - Thanks
It is the Indy dual plane. I see that you are using a spacer with yours. If it is not an "open" spacer, I suggest that you try it.
Yes its a 1" open spacer of the plastic type. They really help against the hot soak in the hot summer months also. Ron
Re: Street/Strip Car Street Usage [Re: 67Satty] #1102651
10/31/11 08:03 PM
10/31/11 08:03 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
1975 PLYMOUTH DUSTER, 2 DR, POP OUT ¼ WINDOWS
ALL LIGHTS ARE FUNCTIONAL AND CAR IS CURRENTLY TITLED, PLATED, AND INSURED
WELD RACING DRAGLITES, 2 X 3.5 FRONTS, 2 X 12 REARS, AND HOOSIER 29/12 SLICKS AND HOOSIER FRONTS . HOOSIER 325/50-15 DOT FOR THE STREET
HOOKER FENDERWELL HEADERS, JET HOT COATED, 3 IN EXHAUST WITH BULLETS
15 GAL ALUMINUM FUEL CELL, ALUMINUM BATTERY BOX, 2 HOLLEY FUER PUMPS AND FRAM FILTORS, 2 HOLLEY REG
FRONT SHEETMETAL IS 1973 DUSTER, GLASS FRONT AND REAR BUMPERS,
PAINT IS BLACK WITH SILVER, PURPLE, PINK, AND BLUE GRAPHICS
MSD 6AL, START/RETARD BOX, PRO BILLET DIZZY, NEW CAP/ROTOR/WIRES
FRESH MOTOR THIS YEAR
MOTOR: 511 CI, 400 BLOCK .030, 4.25 STROKE (4340 FORGED), ELGIN H-BEAM RODS, ROSS F.T.FORGED PISTONS, ALUMINUM VALVE COVERS, MAINS ARE STUDDED, ZERO DECK, LINE BORED AND HONED
DOUG HERBERT ROLLER CAM, SPRINGS, AND LIFTERS, BRONZE GEAR
640 LIFT, 260/272 DUR, 1.6 ROCKERS (HUGHES), .080 PUSHRODS
VICTOR HEADS, HEAD STUD KIT, M-1 INTAKE, 1050 HP 3 CIR DOMINATOR (SET UP FOR E-85)
PETE JACKSON GEAR DRIVE
MILODON PAN, EXTERNAL OILING, SWINGING PICK UP, HUGHES GIRDLE, ALUMINUM TIMING COVERS, ALUMINUM WATERPUMP AND PUMP HOUSING
19 X 27 ALUMINUM RADIATOR, DUAL FAN/SHROUD COMBO, 160 deg T-STAT,
TRANS: 727 TF, LOW GEAR SET, BILLIT DRUM, BOLT IN SPRAG, TRANS BRAKE WITH LOW BAND APPLY, DEEP PAN, TCI ALUMINUM SHIELD, RELOCATED VENT, TRANS COOLER
PTC 8 in CONVERTOR WITH BILLET CORE, 5500 STALL,
SUPERIOR DRIVE SHAFT WITH 4150 U-JOINTS
DANA 60, 35 SPLINE, SPOOL, 4:10 PRO GEAR, DISC BRAKES, CHROME COVER, QA1 SINGLE ADJ COILOVERS
M II RACK/QA1 SINGLE ADJ COILOVERS, GM METRIC FRONT BRAKES, M II SPINDLES, TRAVEL LIMITERS
10 PT, SWING OUTS, ALUMINUM SEATS, STOCK REAR SEAT WITH CARPET, FULL INTERIOR
B&M SHIFTER, VDO AND AUTOMETER GAUGES
PERFORMANCE:
BEST ET: 9.81
BEST MPH: 134.54
BEST 60: 1.29
ON E85
WAXER
Re: Street/Strip Car Street Usage [Re: QWK_ENUF] #1102652
10/31/11 08:08 PM
10/31/11 08:08 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
BEST OF 10.30 WITH DOT's
WAXER
Re: Street/Strip Car Street Usage [Re: QWK_ENUF] #1102653
10/31/11 08:30 PM
10/31/11 08:30 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mopar Performance
