Hello everybody, question for you all.
I have a cross ram Hemi and I'm running the stock, 660cfm, vacuum secondary carbs. Everything runs very well but fuel will start leaking out of one or both of the boosters on my passenger side carb.
Here are the things that I have done:
Change needle and seats.
Adjust float level all the way down to the point where it's just about closed.
Pulled that needle assembly out and exchanged it with one that does not leak....and it still leaks.
Info about the car:
Stock Carter fuel pump.
Idles at 950 in neutral and 850 in gear.
No electric fuel pump.
The cool thing is when you turn the the car off it will still leak even after you turn the car off!!
What am I missing!!
Thanks, Troy
