Re: Slap Happy................
[Re: 4BBodies]
#110121
08/25/08 03:52 PM
08/25/08 03:52 PM
Posts: 12,237 Looking for a way out of Middl...
IMGTX
If it is a round spring with two straight ends sticking out from it it is a tensioner spring that hooks to the front pivot. It is located under the front of the console where the vertical shaft goes through the floorboard. One end connects to small hole on the top tab on the vertical shaft and one goes to the notch in the plate that holds the top of the vertical shaft in place. Hope it helps.
