Re: ROCKERS GET LOOSE [Re: Guitar Jones] #1101130
10/25/11 10:31 PM
10/25/11 10:31 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
Ditch em and save yourself a lot of anguish.For the money Harland Sharp is great and will at least talk to you if you have an issue.
I can hear some valvetrain noise over the exhaust on my car at idle in the garage, standing next to it with the front end off but if I hear something over the exhaust at WOT it's already too late.
Ain't that the truth
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: ROCKERS GET LOOSE [Re: a493demon] #1101131
10/25/11 11:09 PM
10/25/11 11:09 PM
Delray beach, Florida
P
Performance Only Offline
P
a year or 2 ago.i messed up a few and todd called you and you had some.brad
Brad, i remember now. i had a few good pieces left from other sets that saw the same fate as the ones those replaced. hopefully those got you up and running again back then.
machine shop owner and engine builder
Re: ROCKERS GET LOOSE [Re: Performance Only] #1101132
10/25/11 11:35 PM
10/25/11 11:35 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
still on the eng. and doing fine.so far 10.69 if we get one more day hopefully a little faster. brad
Re: ROCKERS GET LOOSE [Re: QWK_ENUF] #1101133
10/27/11 11:45 AM
10/27/11 11:45 AM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
The guys have several good thoughts of why this might happen. One thing I have seen repeatedly that can cause this is incorrect pushrod to rocker geometry (basically wrong pushrod length). This bad angle between the pushrod and the adjuster screw puts pressure on the screw which in turn puts pressure on the aluminum threads eventually wearing them enough that the screw will not stay tight.
Kevin
Re: ROCKERS GET LOOSE [Re: QWK_ENUF] #1101134
10/27/11 01:20 PM
10/27/11 01:20 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I've been running INDY SR rockers for at least 10 years, and never had them come loose. My Buddy has ran the 1.6 INDY SR rockers even longer and never had a problem. He ran the MP .590 cam for years and the rockers were never a problem.
Jeff
69 GTX 68 Road Runner
