340 Timing Chain Cover
#110109
08/25/08 02:34 PM
08/25/08 02:34 PM
Posts: 3,298 Stroudsburg, PA
Erik
Stroudsburg, PA
What are the differences between years? I am building a motor for my '68 'cuda from a '73 block. Will the '73 timing cover work with the '68 water pump? I want to use the original radiator.
Thanks!
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: 340 Timing Chain Cover
[Re: Erik]
#110110
08/25/08 03:03 PM
08/25/08 03:03 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
difference is the timing tab..
68-69 has timing tab on passenger side..
70-73 on driver side...
if you use the 70-73 timing chain cover and 68 water pump you will not be able to see timing tab...
you should match the water pump and timing chain cover
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#110111
08/25/08 03:14 PM
08/25/08 03:14 PM
Erik
Stroudsburg, PA
That's what I thought. I will need to get a '68 cover since I will keep the original radiator.
[Re: Erik]
#110112
08/25/08 03:53 PM
08/25/08 03:53 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
The 273 timing cover and water pump you have on your existing motor should fit just fine on a 340.
I put my '68 318 timing cover and water pump on my 360, no problems, they are all the same family.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#110113
08/25/08 03:57 PM
08/25/08 03:57 PM
Erik
Stroudsburg, PA
I would do that except I already made a deal to sell the 273 as a complete motor carb to pan.
[Re: RapidRobert]
#110115
08/25/08 04:29 PM
08/25/08 04:29 PM
70AARcuda
las vegas
also the damper/balancer can be an issue too...
Tony
[Re: Erik]
#110117
08/25/08 06:11 PM
08/25/08 06:11 PM
70AARcuda
las vegas
the TDC marks on the damper make the side of the engine the timing tab is on...
went you are on tdc on the 70 damper the marks will be showing on the driver side but your timing chain cover will have the timing tabs on the passenger side.
Tony
