Re: Thermoquad secondary tuning?
[Re: ragtop]
#1100948
10/26/11 08:21 PM
10/26/11 08:21 PM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
Since this was not touched on again Ill take another shot. The timing is about initiation of air\flow into the ventures' which starts the fuel flowing out of the boosters. My theory is by making it tighter (or slower acting with restrictors like Doc F) you are allowing the engine speed to come up more before the air door flops open creating the lean spot or possible over rich spot (??). Where as if you set it up like the factor with .1 to .3 of clearance the door is allowing air to begin flowing which pulls the door open immediately (kinda like a door in the house that is shut wont let air through, but if the door is cracked open a little and another door opens somewhere else in the house the pressure drop and air flow through the house either slams/flings open the door)
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
[Re: kilroy]
#1100949
02/27/12 09:28 PM
02/27/12 09:28 PM
Posts: 5,048 Atlanta Indiana
Dave Watt
Atlanta Indiana
The factory setting is to adjust the secondary air door up until it just touches the stop. Then rotate 1.5 turns more on the spring. Are you guys suggesting not even having the door against the stop in the first place? I've tried every setting on the secondary door, the metering rods, and drilled out some squirters to .026", .028" and .031". Nothing will cure the bog at the hit of the throttle. Two different distributors too. Jetting is good at wide open throttle through a 1/4 mile pass.
[Re: a12rag]
#1100954
02/28/12 09:37 PM
02/28/12 09:37 PM
kilroy
Iowa State fan
Im NOT talking about WINDING the secondary spring door, Im talking about bending the choke pull-off to the air door as shown in this figure.
After establishing about 1.5 -2 turns on the spring tension then bend this rod for this clearance. I think you'll find this is the cure; and only then play with spring tension and door stop to tune the fuel curve and the actuation of the air door.
Ive tried to 0.040 clearance like it says, but on my big cam I have to run it tight against the stop as was suggested by tuners to me.
If you need the complete instructions Ill email my complete pdf of the manual.
[Re: kilroy]
#1100956
02/28/12 10:16 PM
02/28/12 10:16 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
Three things I would be experimenting with on the carb in addition to the initial opening gap and accel pump size size (once you have ignition timing close and you determine the linkage is working right). 1) Richen secondary jetting and set open airdoor angle to stock or a little tigher than stock. If you have blocked manifold heat and are running pump gas you will need to step up secondary jetting as well as primary. I would consider going straight to a .149 sec jet to start with. A wide band A/F meter is really useful here. 2) Choke pull-off orifice size (fill it in with jbweld and drill out in steps, starting with a much smaller than stock size) It may be easier to install a different orifice restriction in the vac hose going to the pulloff. I have seen some manual trans pulloffs with an orifice so small you can barely see it. 3) Air door tension (this is not as critcal as one and two, start with 2 turns and change in steps of .25. I dont think you need to go less than 1.5 turns or more than 2.5) If you get stuck PM me and maybe we can talk by phone.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Rapid340]
#1100958
02/29/12 07:30 PM
02/29/12 07:30 PM
Dave Watt
Atlanta Indiana
Tried the pull-off air door setting at .040", didn't help. The current pull-off orifice size is .025". My parts carbs have .028", .031" and .033". I'll have to look at the '72 340 manual carb also. I can easily make restrictors out of nylon rod that are the same outside diameter at the pull-off.
[Re: Dave Watt]
#1100959
02/29/12 09:16 PM
02/29/12 09:16 PM
kilroy
Iowa State fan
I had to run mine tight against the housing stop, not at .040 as suggested; even at 0.040 I had a bog. I know some are run as loose as .100.
Let me ask you what your carbs 4 digit id #?
[Re: kilroy]
#1100960
02/29/12 10:37 PM
02/29/12 10:37 PM
Dave Watt
Atlanta Indiana
Mine is a 6319s, correct for a '73 340 Auto.
Installed a restrictor in the choke pull-off that I drilled to .0135", too small to pull vacuum. Went up to .016". No more bog. The tires spin instantly at the hit of the throttle. Now a new problem has shown up. As the car gets rolling through first gear, the engine feels as though the carb is either way too rich or way too lean, kind of shuddering. Eventually it gets better after shifting into second. Spark plugs checked good. I adjusted the amount of opening on the air door but didn't help the higher RPM situation. I'll hook up the Air/Fuel meter to see what's up. Might have to back the jetting off now just to see if it helps. I'll have to work on it another day.
[Re: Dave Watt]
#1100961
03/01/12 09:22 AM
03/01/12 09:22 AM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
How does one determine this orifice size? Photo?
I installed a restrictor in the choke pull-off that's drilled to .013". No more bog. The tires spin instantly at the hit of the throttle. Now a new problem has shown up.
Did you make this restrictor? Picture?
