mezerie waterpump #1100278
10/23/11 10:02 PM
10/23/11 10:02 PM
southwest pa
bodyworks racing Offline OP
southwest pa
how much horsepower can i expect to gain from electric water pump and going to a electric fuel pump im also running an underdrive pulley on the crankshaft just curious??
68 ROADRUNNER 440 HORSE POWER IS HOW FAST YOU HIT THE WALL TORQUE IS HOW FAR YOU TAKE THE WALL WITH YOU
Re: mezerie waterpump [Re: bodyworks racing] #1100279
10/26/11 01:46 PM
10/26/11 01:46 PM
southwest pa
southwest pa
anybody?
Re: mezerie waterpump [Re: bodyworks racing] #1100280
10/26/11 01:56 PM
10/26/11 01:56 PM
an8sec70cuda Offline
You won't gain anything from the electric fuel pump unless your old mechanical pump was in real bad shape.
The water pump should drop a tenth or so in the 1/4 mile, if you were also previously running an electric fan. If you're removing a belt driven fan AND water pump, then I'd expect .2 to .25 ET reduction.
Not sure on the underdrive pulley, but I wouldn't expect much.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: mezerie waterpump [Re: bodyworks racing] #1100281
10/26/11 02:00 PM
10/26/11 02:00 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
It all depends on the horse power of your car. A stock engine maybe a couple hundereths. if you add up all the claims that every item is suppose drop your ET we all would be running 7's in the quarter.
Re: mezerie waterpump [Re: rowin4] #1100282
10/26/11 04:36 PM
10/26/11 04:36 PM
NC
440Jim Offline
440Jim  Offline
NC
I agree. A 15 second car will gain a lot more ET than a 9 second car. Since you already are running an underdrive (smaller) crank pulley, unless you turn high rpm (>7000) I don't expect much gain.
But the electric water pump is really nice for cooling off the motor after a run. Shut the engine off, run the water pump and electric fan for a few minutes and it cools a bunch.
Re: mezerie waterpump [Re: 440Jim] #1100283
10/26/11 09:55 PM
10/26/11 09:55 PM
southwest pa
southwest pa
the car runs 11.25 to 11.35 in the quarter. i took off the belt driven clutch fan and installed elecric pump and fan .all the crank pulley turns now is the low mount alt.i am hoping for the.20 to .25 as that would give me the 10 "s im lookin for . hagerstown this weekend so we will see thanks for the replys
