Re: How to adjust roller rockers
[Re: JoesMopar]
#1100223
10/23/11 10:04 PM
10/23/11 10:04 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
do not fill the lifters with oil ...you want the plunger to be able to be pushed down with the pushrod while you are adjusting the lifter...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1100225
10/23/11 10:32 PM
10/23/11 10:32 PM
Posts: 2,782 USA
JoesMopar
USA
That's what Rhoads recommends.
[Re: KY Charger]
#1100226
10/23/11 10:43 PM
10/23/11 10:43 PM
70AARcuda
las vegas
The engine has already been running, I'm having to pull the driver side head off due to it leaking antifreeze out in between the block and head so everything was good to begin with. I had drove the car about 5 miles before it started leaking. Not real sure what the problem is until i pull the head off.
e
well ..he does not have Rhoads lifters..
you sure it is not coming out of the end exhaust bolt....those are wet...
Tony
[Re: 70AARcuda]
#1100227
10/24/11 12:26 AM
10/24/11 12:26 AM
Posts: 2,782 USA
JoesMopar
USA
e
That's why I mentioned the type of lifters I used. Sorry for any confusion, I should really stop answering questions on here and leave it to the experts.
Sorry for my post, just do it however you want or ask the guy that built the engine for you originally. I have no clue what I'm talking about.
