Camshaft Duration Question #1100172
10/23/11 08:53 PM
10/23/11 08:53 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline OP
I wiped out a cam lobe on my 408 a couple of weeks ago and looking at whats available for replacement, the original cam I used was a Comp Cams (dont have the model# in front of me but .510/.510 and 268/274 deg of duration are the specs, also dont remember off hand what .050 was) but Summit said it was no longer in production and it would have to be custom ground for $375. But theres a similar Comp cam available with 258/264 degrees of duration (206/212 @.050) in stock for $75 less.
Its a fuel injected engine. Is that shorter duration enough to make a noticable difference? I guess its still enough time for the injectors to fire and the idle wont be as choppy now.
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
71 Country Squire 351W
71 Road Runner 440+6
71 Satellite sedan 318
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
10 Challenger R/T M6
15 Challenger Hellcat M6
Re: Camshaft Duration Question [Re: RangerDan440] #1100173
10/23/11 09:39 PM
10/23/11 09:39 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
That cam should idle as smooth as a stock non-hp 440. I would expect your efi system to be okay with it. Are you running a stock 90's magnum efi system?
Re: Camshaft Duration Question [Re: DaytonaTurbo] #1100174
10/24/11 01:11 PM
10/24/11 01:11 PM
dogdays Offline
dogdays  Offline
Fuel injected motors seem to tolerate cams with wide LSAs better. Look at some catalogs online to see what other cam manuufacturers are offering.
R.
Re: Camshaft Duration Question [Re: dogdays] #1100175
10/24/11 03:09 PM
10/24/11 03:09 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
R.
the wider LSAs tend to give the higher vacuum at idle which allows the computer to better decipher closed throttle idle vs WOT. especially on the Dodge stuff that only uses a TPS, MAP, etc. there's no MAF on the dodges, it's all throttle position and engine vacuum.
that said...my 5.9L was tuned with an SCT flash, and it's running great. stock engine with a hughes whiplash cam. 222/228 @ .050 .544 lift on a 107LSA, it's nice and choppy at idle, but pulls great torque through the RPM range till I start running out of head flow. and this cam idles with only 8.5" of vacuum. only thing I have to "gripe" about, is the pop when lifting the throttle to shift. other than that, it's running perfect!
http://youtu.be/u4YXAdjfO6o
**Photobucket sucks**
Re: Camshaft Duration Question [Re: RangerDan440] #1100176
10/24/11 04:34 PM
10/24/11 04:34 PM
scratchnfotraction Offline
those are the same specs on my SB roller cam
lunati VooDoo
258/264
207/213
.485/.485
I used the comp 901-16 springs and all stock roller valve gear
idles smooth,does have some power for the 318 and right now is in a 91 318 with a q-jet/a999 hs-lu/2.94 gear knocking back about 19-20 mpgs in the 85 stepside
would I want it in my 440 truck..no,but works very well for a daily driver in a SB,IMHO
I do the hughes whiplash for the 440 truck
