Steering coupler rebuild install #1100065
10/23/11 06:37 PM
10/23/11 06:37 PM
Iowa
P
plumcrazyb Offline OP
P
Iowa
Is it even possible to bend the tabs on the metal clip the holds the grease and rubber seal in with motor etc installed? I cannot get anything on it to bend the tabs, header tube also in the way.
Re: Steering coupler rebuild install [Re: plumcrazyb] #1100066
10/23/11 06:42 PM
10/23/11 06:42 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i just tried this the other day with NO engine and a pair of large channel locks. no luck, i get one side then the other pops off
Re: Steering coupler rebuild install [Re: plumcrazyb] #1100067
10/23/11 06:55 PM
10/23/11 06:55 PM
PA
68_CONV_300 Offline
68_CONV_300  Offline
PA
I hate those caps ... never was able to get one to stay on for more than a week YMMV...
here is my suggestion
http://www.amazon.com/gp/product/B003LVR6R0
Re: Steering coupler rebuild install [Re: 68_CONV_300] #1100068
10/23/11 07:05 PM
10/23/11 07:05 PM
Iowa
P
P
Iowa
I was hoping someone would post something like that. How hard to install?
If that little tab only functions to keep that seal and grease in can't one just fill the top with silicone or jb weld?
Re: Steering coupler rebuild install [Re: plumcrazyb] #1100069
10/23/11 07:27 PM
10/23/11 07:27 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Pre-bend them, just a little on each one & then start the back sides first. With a little practice you can roll them on every time & they will stay.
Re: Steering coupler rebuild install [Re: Alaskan_TA] #1100070
10/24/11 11:49 AM
10/24/11 11:49 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
They are a pain. Someone sells a rubber boot that slips over the top of the coupler and replaces the metal lid. Add a zerk fitting low on the coupler body and you're set.
Re: Steering coupler rebuild install [Re: Montclaire] #1100071
10/24/11 03:53 PM
10/24/11 03:53 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Re: Steering coupler rebuild install [Re: Montclaire] #1100072
10/24/11 05:52 PM
10/24/11 05:52 PM
templeton,ma
coro500net Offline
coro500net  Offline
templeton,ma
Steer and Gear has the boot and it works way better than the factory setup.Little tough getting it over the pins,just fill coupler with grease and your done.
