2003 Dodge Ram Code P0442 . #1100051
10/23/11 05:46 PM
10/23/11 05:46 PM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
Code P0442 = Evap. Emmissions leak. What/ Where to look for ?.
Re: 2003 Dodge Ram Code P0442 . [Re: 493RT] #1100052
10/23/11 05:58 PM
10/23/11 05:58 PM
PA
68_CONV_300 Offline
68_CONV_300  Offline
PA
thats a small evap leak code ... check to make sure the gas cap is on tight and the check valve in it is not bad. reset the code and see what happens ... if it comes back there is probably a small leak in one of the rubber lines from the tank to the charcoal canister ...
