lexan #1099799
10/23/11 08:43 AM
10/23/11 08:43 AM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
how much weight could be saved by putting lexan for the rear glass in a 69 dart? Thanks Rich
Re: lexan [Re: Rich970] #1099800
10/23/11 09:31 AM
10/23/11 09:31 AM
Super Scamp Offline
Super Scamp  Offline
Rich.
28.765 lbs saved on rear glass alone
Just One Man's Opinion Mopar Mafia Racing
Re: lexan [Re: Super Scamp] #1099801
10/23/11 10:37 AM
10/23/11 10:37 AM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Question:
If you were to add weight to your car where would it be the most benefit?
Answer:
Above the rear wheels as high as possible. (rear window)
Just my
Re: lexan [Re: AAR-B4] #1099802
10/23/11 11:04 AM
10/23/11 11:04 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
All fine and good but there's only so many places you can take it from the front.
I am thinking of putting lexan in the back and maybe a lightweight battery and glass trunk lid.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: lexan [Re: deaks] #1099803
10/23/11 11:17 AM
10/23/11 11:17 AM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Just saying, consider the cost and effort. Building horsepower might be the better option.
Re: lexan [Re: AAR-B4] #1099804
10/23/11 12:10 PM
10/23/11 12:10 PM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
ok so whats the cost ? how hard are they to install ?
Re: lexan [Re: AAR-B4] #1099805
10/23/11 12:49 PM
10/23/11 12:49 PM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
i thought loosing weight was the cheapest was to go guicker ? .010 per 100 lbs
Re: lexan [Re: Rich970] #1099806
10/23/11 12:52 PM
10/23/11 12:52 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
And it's easier on the drivetrain.
This is a mod i'm looking to do, so i'll give it a bump.
Mick
best 60ft 1.36
Re: lexan [Re: Rich970] #1099807
10/23/11 01:06 PM
10/23/11 01:06 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use the factory glass as a template. Buy a 4'x8' sheet and cut them out with a saber saw. Install just like the factory windows. You can make the rear side windows and fix them in position. Get rid of the regulators,more weight.
Doug
Re: lexan [Re: deaks] #1099808
10/23/11 01:09 PM
10/23/11 01:09 PM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
Lighter is better. like you said a tenth for every 100 lbs at that HP level.
and besides HP cost more money.
Re: lexan [Re: bumps440] #1099809
10/23/11 01:10 PM
10/23/11 01:10 PM
tboomer Online work
tboomer  Online Work
Mick...What does your car weigh now? Sorry for the hi-jack..
Re: lexan [Re: Rich970] #1099810
10/23/11 01:31 PM
10/23/11 01:31 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Just offering a suggestion, do what you want.
I reinstalled the glass on my Cuda because the lexan install job was bad and it was scratched. Didn't lose any et.
Re: lexan [Re: Rich970] #1099811
10/23/11 02:59 PM
10/23/11 02:59 PM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
how hard is the rear glass to install ? flat or formed lexan ?
Re: lexan [Re: Rich970] #1099812
10/23/11 03:22 PM
10/23/11 03:22 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
If I'm not mistaken, there are some pretty good cuves in that rear glass. That will be really tough to duplicate with lexan. Anything thicker than 1/8" likely won't take the bend cold and if you heat it enough to shape it will develop air bubbles in it and look like hell. 1/8" is probably too thin and will blow out.
Re: lexan [Re: Stanton] #1099813
10/23/11 03:40 PM
10/23/11 03:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've bent 1/4" with no issues what so ever... if you
get air bubbles you are heating it WAY TO FAST... I
have watched the guys in the plastic shop at work
heat 4'X 8' sheets up to 1/2" and turned out perfect
Re: lexan [Re: MR_P_BODY] #1099814
10/23/11 05:07 PM
10/23/11 05:07 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I have it in my 68, all but vent windows and front window. It used to be lexan front, but got scratched up. 1/8 inch is easy to work with.
Re: lexan [Re: Mopar-Al] #1099815
10/23/11 05:54 PM
10/23/11 05:54 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I see you've used the original rubber, did you heat it to make it fit.
Ted
I reckon my car is around 3000# + my 175.
Mick
best 60ft 1.36
Re: lexan [Re: Mopar-Al] #1099816
10/23/11 06:37 PM
10/23/11 06:37 PM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
VERY NICE CAR ! did you have to get a new gasket ? could it be flush mounted ? did you make or buy it pre-cut? i have lexan everywhere except the rear. thanks for the pictures. that engine looks to be set back prety good.
Re: lexan [Re: Rich970] #1099817
10/23/11 08:39 PM
10/23/11 08:39 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Only the front glass has a rubber gasket. The rest of the lexan was trimed to fit the channel the sealed in . The chrome is screwed down. This is a tube chassis car. Weighs a little over 2600 with me in it. Or I should say it was weighed with a 185 lb driver at gateway track 2 yrs ago and it was 2625. I'm 50 lbs heavier
Re: lexan [Re: Mopar-Al] #1099818
10/23/11 09:10 PM
10/23/11 09:10 PM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
thanks for the help everyone .
