aluminum radiator question #1099698
10/22/11 11:24 PM
10/22/11 11:24 PM
superstreet1896 Offline OP
looking to get a new aluminum radiator. i have just a stock radiator in it now, with a clutch fan.. looking to go all electric water pump and fan. thinking a motor on the stock water pump and then and electric puller syle fan with a shroud. its going in a 67 barracuda, 360, car runs mid 11's. what is everybody running for cooling. would like to just have a bolt in deal, no fab work. pics would help too. thanks
Re: aluminum radiator question [Re: superstreet1896] #1099699
10/23/11 12:17 AM
10/23/11 12:17 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
i have a champion rad. work's good and for the price you can't beat it. brad p.s i think they have a add in race part's for sale.
Re: aluminum radiator question [Re: a493demon] #1099700
10/23/11 12:23 AM
10/23/11 12:23 AM
I just bought one of these myself and waiting for it to arrive. Rad, shroud and fans included with the price is a tranny cooler.
Re: aluminum radiator question [Re: a493demon] #1099701
10/23/11 12:27 AM
10/23/11 12:27 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i use a Cheapo Chinese 2 row alloy rad that i made my own shroud & mounted a Cheapo Chinese curved blade fan to. it works well & cools the motor down quickly between rounds. if i were using it for the street i might have to upsize as the big block can gain on it at times.
Re: aluminum radiator question [Re: superstreet1896] #1099702
10/23/11 12:49 AM
10/23/11 12:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I went with a Summit 3 pass 2 core(1" cores)radiator
with a HHS fan(or what ever the letters are)... this
is going in my Rampage for the street/strip
Re: aluminum radiator question [Re: MR_P_BODY] #1099703
10/23/11 12:58 AM
10/23/11 12:58 AM
looked at the champion but i dont see a direct fit for a 67-69 A body. been looking at the summit but i need to measure the one i have to see how big it is. im looking for the easiest fit, would like to just bolt it in and off i go. im not a great fab. keep the ideas comming, thanks
Re: aluminum radiator question [Re: superstreet1896] #1099704
10/23/11 01:05 AM
10/23/11 01:05 AM
PA
moparacer Online content
moparacer  Online Content
PA
I have a Jegs radiator I made to direct fit a 68 Dart and it drops right in my 67 Barracuda I am working on.
All rubber mounts and isnt hard to do.
If you want I will take some pictures of it tomorrow night when I get home from the Maple grove 10K footbrake race.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: aluminum radiator question [Re: superstreet1896] #1099705
10/23/11 01:07 AM
10/23/11 01:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Summit does offer direct replacements but for a couple
of mounts the price goes UP
Also the Summit brand is made by Northern Radiator
which is American made
Re: aluminum radiator question [Re: moparacer] #1099706
10/23/11 01:08 AM
10/23/11 01:08 AM
that would be great. good luck at the 10k one of my favorite tracks
Re: aluminum radiator question [Re: superstreet1896] #1099707
10/23/11 01:15 AM
10/23/11 01:15 AM
Canada
CrAzYMoPaRGuY Offline
Canada
I just bought a Champion 3 core for my Charger.... didn't have a rad and the one I bought is probably cheaper than any 26" stocker price...
CrAzYMoPaRGuY
Re: aluminum radiator question [Re: CrAzYMoPaRGuY] #1099708
10/23/11 02:18 AM
10/23/11 02:18 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I have one of the Summit Radiators in the Satellite. Fits like a glove, and keeps up with the 452 on the street just fine. Had my buddy fab me up a custom shroud. Looks pretty good, and works great.
Re: aluminum radiator question [Re: StealthWedge67] #1099709
10/25/11 10:26 PM
10/25/11 10:26 PM
what do you all think about running stock water pump with a napa motor on it. and then an electric puller fan??
Re: aluminum radiator question [Re: superstreet1896] #1099710
10/26/11 10:13 AM
10/26/11 10:13 AM
upstate new york
71cuda Offline
71cuda  Offline
upstate new york
champion,just had to drill a couple of holes.works great,car runs mid 11's.the moroso belt drive pump works great at the track but can't keep up on the street.
Re: aluminum radiator question [Re: CrAzYMoPaRGuY] #1099711
10/26/11 01:21 PM
10/26/11 01:21 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Yep. They are nice and the price is right. I got mine for like 200 bucks. I am using one made for a late corvette in my dakota, and I read in I think car craft that there is a 2 speed fan from a taurus that works perfectly for it with a 100 amp alternator. I am going to give it a try with that fan.
I have no plan messing with an electric pump on the street.
Re: aluminum radiator question [Re: 71cuda] #1099712
10/26/11 01:29 PM
10/26/11 01:29 PM
PA
PA
Sorry it took me so long. Here are the pictures of the way I do a aluminum rad in an a body.
I use 90s dodge dakota lower rubber mounts in the holes that are already in the core support. I weld a 1/2 inch dowel rod on each tank and weld a flat piece on each one to set on the mounts. Then, I weld two pieces of angle at the top of each tank that line up with the holes that are already in the upper part of the core support.
I stick early 90s dodge caravan rubber mounts through thee holes and draw them up with 1/4 inch bolts. When its done, the whole radiator is mounted in rubber and all it takes is two bolts up top and it comes right out..
Re: aluminum radiator question [Re: moparacer] #1099713
10/26/11 01:30 PM
10/26/11 01:30 PM
PA
PA
Holes in bottom of support.
Re: aluminum radiator question [Re: moparacer] #1099714
10/26/11 01:31 PM
10/26/11 01:31 PM
PA
PA
Holes in top of support with caravan bushing in it.
Re: aluminum radiator question [Re: moparacer] #1099715
10/26/11 01:32 PM
10/26/11 01:32 PM
PA
PA
Radiator setting in bottom hole.
Re: aluminum radiator question [Re: moparacer] #1099716
10/26/11 01:34 PM
10/26/11 01:34 PM
PA
PA
Radiator bolted in with top bracket and bushing.
Re: aluminum radiator question [Re: moparacer] #1099717
10/26/11 01:44 PM
10/26/11 01:44 PM
PA
PA
Setting in my 67 Barracuda.
