clutch for Lenco #1099125
10/22/11 09:45 AM
10/22/11 09:45 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
is here someone who uses some other brand clutch for Lenco tranny? Hydraulic pedal ones? I heard that Lenco`s own clutch needs to grind surfaces after some runs, it needs special grinding machine and so on...
What do guys who use Lenco in street/strip cars?
Is there some alternative or not?
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: clutch for Lenco [Re: Georg] #1099126
10/22/11 09:54 AM
10/22/11 09:54 AM
Long Island, NY
B1Johnny Offline
B1Johnny  Offline
Long Island, NY
hi Georg,i use a ram billet 10 inch dual disc. i bracket race with it.every other time out i pull it apart and sand the discs to get theglaze off. if i am at a two day race i will zero it out at the end of the first day.hope this helps
Re: clutch for Lenco [Re: B1Johnny] #1099127
10/22/11 11:21 AM
10/22/11 11:21 AM
ohio
Rich970 Offline
Rich970  Offline
ohio
what do you mean by zero out ?
Re: clutch for Lenco [Re: B1Johnny] #1099128
10/22/11 02:34 PM
10/22/11 02:34 PM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
and it cost some 3500 dollars!?
Re: clutch for Lenco [Re: Rich970] #1099129
10/22/11 03:25 PM
10/22/11 03:25 PM
Roanoke Va
gearjammerdart Offline
Roanoke Va
Adjusting the ring height back to the original setting. As the clutch slips it wears the disc so you adjust the ring height this way you can keep track of your pressures.
Donald
69 Dart swinger 417 W8 Liberty 5 speed
6.03 @114/9.49 @141 on motor 5.30 @131 on juice 1/8th mile 28x10.5's at 3200lbs
70 Challenger RT 440 4-speed 4:10 Dana
http://www.youtube.com/watch?v=VowFy4nDdfI
Re: clutch for Lenco [Re: Rich970] #1099130
10/22/11 03:46 PM
10/22/11 03:46 PM
Long Island, NY
B1Johnny Offline
B1Johnny  Offline
Long Island, NY
hey rich the discs wear about .004 per pass,they give you a dial indicator with the clutch you loosen the nuts on thepressure plate and reset the ring height,by adjusting the stands using the indicator.then you set the air gap by adjusting the linkage.the clutch cost me 3500,and you need a race pak or some other form of data to see when it is locking up.you can change that bybase pressure or counter weight pressure.
Re: clutch for Lenco [Re: gearjammerdart] #1099131
10/22/11 03:48 PM
10/22/11 03:48 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
you could also just ditch the clutch if its to much work for you and put a converter drive in front of it.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: clutch for Lenco [Re: B1Johnny] #1099132
10/22/11 05:05 PM
10/22/11 05:05 PM
ohio
Rich970 Offline
Rich970  Offline
ohio
Thanks John for that info.
Re: clutch for Lenco [Re: gearjammerdart] #1099133
10/22/11 05:19 PM
10/22/11 05:19 PM
ohio
Rich970 Offline
Rich970  Offline
ohio
Donald
thanks Donald. sorry to get off the original topic. dont they have dual friction clutches that can be used with the lenco that need less maintenance?
Re: clutch for Lenco [Re: Georg] #1099134
10/22/11 05:36 PM
10/22/11 05:36 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Georg,
Are you considering to run a CS1,CS2 type Lenco or are you referring to the 1200 Street model ?
Think it would make a big difference on clutch selection, although cost will be similar, something like a Bonafante will be around $3500. But will need maintenance/checking, but less so on a mainly street application. Then again, what sort of HP you looking to put through it.
A bruno type Lenco, with a converter, as mentioned earlier is another option to consider
Re: clutch for Lenco [Re: mopar_mark] #1099135
10/23/11 03:42 PM
10/23/11 03:42 PM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
Georg,
Actually CS1, CS2 or 1200 model choose is still pending. My motor makes around 850hp as naturally aspirated right now but future plan is to use turbocharger...so chooseing is hard. Probably its gonna be CS1 or CS2. Lenco is far not cheap tranny and I want to make correct pick up first time so I can use it later on if motor picks up more horses
Re: clutch for Lenco [Re: Georg] #1099136
10/24/11 01:12 AM
10/24/11 01:12 AM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Georg,
You can put any type of clutch in front of a Lenco that they make an input shaft for. You need to pick a clutch for whatever you're mostly using the car for. If street, you need a street clutch, if street/strip, or strip only, pick a clutch designed for your HP and car weight. The CS1 and CS2 will take anything you can throw at it, up to 3000HP for the CS1. The CS2 is a slightly smaller case if you have space limitations but will still handle 2500hp. The ST1200 is just that, a street version thats rated at 1200hp. They use aluminum cases instead of mag like the race versions and 8620 material for the gears instead of 9310. The 8620 is the same material used in most ring and pinions and is a little harder for better wear on the street. Thats how Lenco can get the cost down a little for the street version. One thing to consider is heat buildup with the Lenco if you are doing a lot of cruising, I know my CS2 doesn't have any provisions for fluid cooling although the ST1200 might. BTW, I'm running a Bruno convertor drive in my altered and honestly think it would be streetable if I were to put it in a bodied car. You might want to look at a Lencodrive also, roughly same size as a glide in 2-speed configuration but you have the flexibility of adding more standard CS2 sections to it to make a 3-4 or even 5-speed. All it takes is dollars.....
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: clutch for Lenco [Re: 23T Hemmee] #1099137
10/24/11 02:09 AM
10/24/11 02:09 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
Georg,
Thanks a LOT Ronny for detailed answer! One thing I dont understand about Lencos and that is - why the hell they cost so much!? They are actually very simple transmissions...
Re: clutch for Lenco [Re: Georg] #1099138
10/24/11 03:42 AM
10/24/11 03:42 AM
Cab_Burge Online work
Cab_Burge  Online Work
They cost that much because racers will pay that much Have you look for used ones anywhere? At one time you could find them in National dragster occasionaly, epsecially when Pro Stock went back to conventional transmissions with slipper clutches years ago
Re: clutch for Lenco [Re: Cab_Burge] #1099139
10/24/11 07:17 AM
10/24/11 07:17 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
I searched used ones from racingjunk.com There are couple but its quite risky especially when I cant see what I buy...only pictures and nice description may be errant
Re: clutch for Lenco [Re: Georg] #1099140
10/24/11 11:12 AM
10/24/11 11:12 AM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Georg,
I agree, they are simple transmissions, but they are pretty much bulletproof, you can spend almost as much on a Powerglide that will handle close to the same HP but you would be rebuilding it every 10-15 passes.
A better source you might look at is:
http://www.insidetopalcohol.com/forumdisplay.php?13-NRE-X-1-Heads-Free-Classifieds
Got your PM, going to be out most of the day today, but when you get a chance give me more info about your car and what type of usage you intend to do with it. I'll try to help any way I can.
Ronny
John 14:6
Re: clutch for Lenco [Re: Georg] #1099141
10/24/11 03:56 PM
10/24/11 03:56 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I use B&J trannys,same strength as Lenco.
We resuface the clutch disc and floaters every run!
Use to have portable clutch grinder that we took to the track, but it is not accurate enough.
Bought this 11K surface grinder to do the whole clutch assy including the pressure plate and flywheel after every race. We would put together enough clutch packs for the race before we leave the shop.
The clutch grinder.
All the fixtures to maintain your clutch.
Tool to check my work. It isn't cheap to run a clutch on the race track.
Re: clutch for Lenco [Re: Challenger 1] #1099142
10/24/11 06:26 PM
10/24/11 06:26 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
That's the many reasons I went Bruno drive!
Re: clutch for Lenco [Re: B1Johnny] #1099143
10/24/11 09:34 PM
10/24/11 09:34 PM
Cincinnati, Ohio
Cincinnati, Ohio
When I started racing alcohol, we would zero the clutch after the first run and then run it again and see how much it got eat up. Sometimes we would go 3 runs. It was way more fun racing then, with only 4 guys.
Then came screw blowers(Wipple) and we were lucky to get 2 runs. Then came the PSI blowers and the clutch get's fried every run. And it took 6 guys and me to maintain and race the car.
If we really miss the tuneup with it we can fry a set of brand new floaters with one run and they won't clean up even with our hi dollar grinder because of hot spots.
It's like money. I never got attached to any of my race part's.
This run the clutch was perfect, super smooth but the motor had a bit more bottem end because we retarded the cam just 1.5 degees right before this run. The car has a 11 gal fuel tank all the way up front plus I have 49 LBs of lead plate in the nose also and it still did this. We added more weight to the front after this run. I pedaled the car down with out hurting any wheels or tires, luckly.
Re: clutch for Lenco [Re: Challenger 1] #1099144
10/25/11 01:04 AM
10/25/11 01:04 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
^^^^^^^^^^and all of this is why i said converter drive.
