Page 3 of 3 1 2 3
Re: Any reasons why not to use a HV Oil Pump ??? [Re: DaytonaTurbo] #1098901
10/23/11 03:39 AM
10/23/11 03:39 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The nice thing about the aftermarket and "Hemi" oil pans (besides holding more oil) is they have baffles to reduce the oil sloshing around which can uncover the oil pickup.
Re: Any reasons why not to use a HV Oil Pump ??? [Re: 451Mopar] #1098902
10/23/11 10:09 AM
10/23/11 10:09 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Ran alots of HV pumps since the mid 70's. Never a problem.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Any reasons why not to use a HV Oil Pump ??? [Re: 62440] #1098903
10/23/11 11:36 AM
10/23/11 11:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I was just looking at 440Source for the distributor driveshaft and found something Disturbing. They are selling in Their own words "Heavy Duty pinned Intermediate shaft - Steel gear (needs slight grinding of hex flats to fit pump) $25" "Needs Slight Grinding of the Hex Flats to fit the Pump" That doesn't sound right to me !!! Wouldn't the shaft be case hardened and would not grinding ruin the hardening ???
another QUALITY PRODUCT brought to you by .... ...
If you are going to run the HV pump it would be a good idea to install an HD drive, and one you don't have to grind to fit ....
that's too funny , you can't make s.... like that up ...
Re: Any reasons why not to use a HV Oil Pump ??? [Re: JoesMopar] #1098904
10/23/11 11:57 AM
10/23/11 11:57 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Why does everyone want a HV oil pump?
For the same reason they want 440 heads on their 383's
Same deal with 1.6 and 1.7 rocker arms!
IMO I have discovered like many other builders that a HV oil pump isn't needed in most cases, especially if all your clearances are within tolerance.
HV pumps take a HD drive like has been mentioned and takes extra horsepower to turn it.
Those who say they have never ran out of oil with one and a stock 4-5 QT pan has never run there car for a extended periods of hi RPM to know.
My
My current 340 with a 7 qt pan has a used standard oil pump in it. I ran it hard and long at 4500-5000 rpm for over 5 miles at time on the salt flats. It held up and the gauge held steady oil pressure the whole time. With a used standard oil pump when I put it togeather in 2007.
Re: Any reasons why not to use a HV Oil Pump ??? [Re: 62440] #1098905
10/23/11 11:59 AM
10/23/11 11:59 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Or what if too much is "ground"??
Ever grind on an allen wrench to get it to fit a worn out, stuck in socket head bolt? Yeah hardly ever works. Take out too much and you lose the shaft and the pump.
440 source has plenty of machining capabilities now, why not fix it?
Must be "metric sized"
Re: Any reasons why not to use a HV Oil Pump ??? [Re: NTOLERANCE] #1098906
10/23/11 12:29 PM
10/23/11 12:29 PM
moparmarks Offline
moparmarks  Offline
Some good points made. My use of them has been on daily street driven cars with mild motor mods, cams, headers ect. Not cars that see the upper RPM's all time time. My reasons for using them was for more low rpm,s such as idling for 15 min in a drive through. Not WOT all the time. Sure they see a few burnouts and WOT for a few sec on the highway but not for a living.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Any reasons why not to use a HV Oil Pump ??? [Re: moparmarks] #1098907
10/23/11 02:16 PM
10/23/11 02:16 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Not much PSI is needed at low RPMs and especially not at idle where there is no load on the engine.
I would tend to think that extra PSI would increase bearing wear.
Re: Any reasons why not to use a HV Oil Pump ??? [Re: SomeCarGuy] #1098908
10/23/11 03:51 PM
10/23/11 03:51 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Never heard that before, care to explain?
Re: Any reasons why not to use a HV Oil Pump ??? [Re: jcc] #1098909
10/23/11 05:02 PM
10/23/11 05:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: Any reasons why not to use a HV Oil Pump ??? [Re: Challenger 1] #1098910
10/23/11 05:23 PM
10/23/11 05:23 PM
Canada
CrAzYMoPaRGuY Offline
Canada
My
I'll have to be the one I guess.
I've had tons of vehicles with HV pumps. No deep pans.
10W30 oil, windage tray and a quart over full. Did it for 30 years, ain't gonna change now either.
My Jensen is a stock pan, windage tray and runs a quart over full of 10W30. I beat it senseless all the time.
My Charger is a stock depth pan, windage tray and a quart over full of 10W30 weight.
Running 20w50, no windage tray and stock oil level isn't MY idea of "an ounce of prevention"....
CrAzYMoPaRGuY
Re: Any reasons why not to use a HV Oil Pump ??? [Re: SomeCarGuy] #1098911
10/23/11 05:58 PM
10/23/11 05:58 PM
moparmarks Offline
moparmarks  Offline
Long idle can starv the cam and valve train so I've heard. Isn't that why cam break in requires 1500 rpm?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Any reasons why not to use a HV Oil Pump ??? [Re: CrAzYMoPaRGuY] #1098912
10/23/11 08:48 PM
10/23/11 08:48 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
My
In fact when the windage trays were made available service reps advised running an extra quart. I seem to remember that it was also in a FSM but wouldn't swear to that. Not to prevent the pan from being pumped dry but to prevent oil from being pulled away during launch or hard braking.
Re: Any reasons why not to use a HV Oil Pump ??? [Re: MoparforLife] #1098913
10/23/11 11:42 PM
10/23/11 11:42 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
My 383 Valiant 4-speed with stock pan and pump would lose oil pressure momentarily (idiot light would come on) whenever I launched at 3000 rpm or higher... A deep pan and windage tray fixed that
Re: Any reasons why not to use a HV Oil Pump ??? [Re: JohnRR] #1098914
10/23/11 11:54 PM
10/23/11 11:54 PM
SomeCarGuy Offline
SomeCarGuy  Offline
Just thinking about more pressure and how that might erode the bearings over time. Just a thought.
Re: Any reasons why not to use a HV Oil Pump ??? [Re: moparmarks] #1098915
10/23/11 11:56 PM
10/23/11 11:56 PM
SomeCarGuy Offline
SomeCarGuy  Offline
Cams get splash oiled, not pressure. Valves, you may have something, but who is idling their engine that long on a regular basis? In a hobby car I'd guess not near as much as your DD.
Page 3 of 3 1 2 3
