Greetings: I have an 83 Mirada, the AC works, but I can't get the heater to work. The underhood valve works, but the heater won't...heat. It has Climate Control, so the temperature control is some kind of electronic switch for the temp , not the typical cable I am used to control the flapper in the AC box under the dash.
How can I fix this?
Thanks in Advance!!!
