Quality Fuel Sending Unit
#1098727
10/21/11 08:07 PM
10/21/11 08:07 PM
Posts: 1,884 Tracy CA
rabid scott
"You're Where?"
"You're Where?"
Tracy CA
So I installed a new stainless unit in my Valiant... and it only reads the first 7 gallons of the tank. When it's full its full... when the gauge reads empty I've only used 7 or so gallons of gas. I either need to fix or replace it. I didn't keep any of the box or info from the last unit so I don't know who to avoid, but who makes a good one that reads correctly? Unless someone knows how to make this one work correctly.
Re: Quality Fuel Sending Unit
[Re: rabid scott]
#1098728
10/21/11 11:58 PM
10/21/11 11:58 PM
RapidRobert
google it "Moparts sending unit issues" (be sitting down)
[Re: RapidRobert]
#1098729
10/22/11 12:03 AM
10/22/11 12:03 AM
Posts: 5,044 At a gas station near you
badblack68
Unless you find a real, genuine Mopar NOS unit your S.O.L. I have yet to find an aftermarket unit that gets installed and works correctly without any issues. Good luck.
Nobody gets in to see the wizard! Ain`t no way! Ain`t no how!
[Re: badblack68]
#1098730
10/22/11 08:38 AM
10/22/11 08:38 AM
Posts: 5,278 San Jose, California
DennisH
Vacation
Vacation
Ditto.
[Re: mikemee1331]
#1098734
10/23/11 01:48 PM
10/23/11 01:48 PM
Posts: 3,344 Central TX
roe
Central TX
I always say this and no one ever responds to it, but...I picked mine up from autozone, and after running my own bigger, home made ground strap from the sending unit to the frame, it reads very accurately. When its full it reads full, and when it is almost empty, it reads empty. Works great and Im happy with it. It is a Spectre brand from autozone.
roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: roe]
#1098735
10/23/11 02:50 PM
10/23/11 02:50 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
roe
on the contrary!! i have read your suggestion (it makes sense) and have passed it on several times!
[Re: roe]
#1098737
10/23/11 09:45 PM
10/23/11 09:45 PM
Posts: 228 FL
HelleOnWheels
FL
roe
I'd like to hear more about this homemade bigger grounding strap:)
[Re: HelleOnWheels]
#1098738
10/24/11 02:43 PM
10/24/11 02:43 PM
roe
Central TX
roe
At the advice of TheRocks (Rocky), a member here, instead of using the factory style grounding strap, I made my own. Dont remember the guage but it was a nice thick wire. I clamped one end to the normal spot on the sending unit with a small metal hose clamp (the ones that tighten with a screw), and I ran the other end to a freshly cleaned, nice and shiny bare metal spot in the frame and screwed it in. Voila, worked like a charm.
roe
