Re: 340 ballast resistor
[Re: sailboat]
#1098059
10/20/11 12:05 PM
10/20/11 12:05 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I am updating my dual point distributor in my 70 TA with an electronic unit. Do I need to change my ballast resisitor or my electronic regulator as well?
i'm confused (as usual). are you saying you are upgrading to an electronic ign or just changing out your dizzy?? like i said, i'm confused!
[Re: sailboat]
#1098060
10/20/11 03:32 PM
10/20/11 03:32 PM
Posts: 1,564 St. Clair Shores, Michigan
bigsbigelow
You need the electronic box (orange or chrome depending on your set-up), the wiring harness, and the dist. to switch over.
[Re: sailboat]
#1098061
10/20/11 04:08 PM
10/20/11 04:08 PM
RapidRobert
Your (electronic) reg can stay. Many ways to go. could get a JY dizzy (B or RB) for cheap & the wear is negligible and a parts house 4 pin ECU (they're good/cheap) such as an AutoZone borg warner CBE142 or others & dont wast your $$$ on a MP chrome one and the orange MP ones (can) have issues. That only leaves the coil and the ballast & many options there & can go with a full 12V coil and no ballast probably an E coil. I'd google it & read up. Alot of gain will be from tuning the subsystems in the dist (initial/total/springs/vac adv) in order one at a time. Some ECU's reportedly increase dwell but the main power is in the coil/ballast choice. EDIT missed the 340 part, of course you'd want a SB electronic 70's 318/360 JY dizzy & take it apart & clean/lube/toss the heavy spring with the long loop & sub in a mr gasket or MP light one keeping the other OE light spring
[Re: sailboat]
#1098068
10/23/11 05:25 PM
10/23/11 05:25 PM
mikemee1331
bethlehem pa
Thanks for the info. Its a "new" orange box, but I still have the original coil. So based upon that, I need the ballast resisitor? Unless I get a "new" 12V (100% 12 v) coil.
yes sir!
[Re: sailboat]
#1098075
10/23/11 05:34 PM
10/23/11 05:34 PM
mikemee1331
bethlehem pa
I can return the ornage box to my supplier. What do you suggest for an ECU then?
again, any Mopar ECU from your favorite parts store. and a dizzy is NOT an e-coil.
