Vacuum Advance Distrubutor and A/F?
#1097471
10/19/11 11:20 AM
10/19/11 11:20 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
I am currently running a mechanical advance distributor and my 30mph to 75mph cruising A/F shows 14.2-14.6. If I was to swap from a mechanical only distributor to a vacuum advance distributor, and I kept the initial and the mechanical the same, what would my cruising A/F do once the vacuum advance is added to the curve? I am assuming that I will I see the whole curve go leaner, would this be correct?
My A/F currently goes richer once I am at a cruise and I let off of the accel pedal. Would the VA distributor keep the A/F leaner since there is more vacuum made during decel? Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Vacuum Advance Distrubutor and A/F?
[Re: DaytonaTurbo]
#1097473
10/20/11 08:42 PM
10/20/11 08:42 PM
YO7_A66
Indiana
I was hoping only a little bit. Thanks for the reply.
[Re: lewtot184]
#1097475
10/22/11 07:09 PM
10/22/11 07:09 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Short answer: Basically No. But it does change the products of combustion. Fuel & air at any given rpm and throttle position should equal the total combustion products and air out. But the WBO2 doesn't measure them all. So it may indicate a change in AFR when there is none. A more complete answer can be found by searching Innovate's Forum. Here's one that is pretty thorough Is it ready for the track, post numbers 10 & 16.
[Re: Mattax]
#1097476
10/23/11 04:59 PM
10/23/11 04:59 PM
YO7_A66
Indiana
Mattax, Thanks for the PM and for the link. It was good reading. ![](/ubbthreads/images/graemlins/thumbs.gif)
