ebay HEI distributor? #1097395
10/19/11 05:41 AM
10/19/11 05:41 AM
kerrville, tx
bigbertha72 Offline OP
kerrville, tx
Is the ebay hei dizzy any good? Or is it a piece of junk, seems to good to be true for the price. Anyone try one of these http://www.ebay.com/itm/MOPAR-DODGE-CHRY...=item519ada2bb9
Re: ebay HEI distributor? [Re: bigbertha72] #1097396
10/19/11 10:01 AM
10/19/11 10:01 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've ran a few different ones of these on various projects and never had any trouble with them. Always ran better than with the junk I took off. You can recurve the advance with a gm hei advance kit.
Re: ebay HEI distributor? [Re: bigbertha72] #1097397
10/19/11 12:13 PM
10/19/11 12:13 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
And here's another option that is a bit nicer.
Works the same but doesnt have the module out in that little housing.
Might fit a little better depending on what you have going...
http://www.ebay.com/itm/120685620555?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I like the large cap GM version because of how it only needs 1 wire to run. Coil and everything is in it, but it likely wont clear the firewall in an a body.
