Page 1 of 3 1 2 3
who would you get to build a Hemi? #1095914
10/16/11 10:59 PM
10/16/11 10:59 PM
Canada
Cape Offline OP
Cape  Offline OP
Canada
I have a 426 Hemi stock bore stock stroke a mopar crate engine and not to happy with its performance if I had my time back i would have had one built. But over the winter I plan to have it modified a better combo. Everyone I have talked to say the mopar crates are a S@#t engine. Im just wondering who you guys would have build yours? but in this combo. A 69 4 speed charger street strip but mostly strip everything else is done on the car hemi trans mcleod soft loc clutch dana 60 4.10 detroit locker and cal tracs mono leaf and slicks. the only street driving I do with the car is car shows. Im thinking of taking it to FHO. Thanks
Re: who would you get to build a Hemi? [Re: Cape] #1095915
10/16/11 11:07 PM
10/16/11 11:07 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Dave Dudek
Re: who would you get to build a Hemi? [Re: Cape] #1095916
10/16/11 11:14 PM
10/16/11 11:14 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Where abouts in Canada are you? I have an engine builder here in Lockport NY near me, and not far from Niagara Falls, that does a lot of Hemi's, and man, do they run...Last year I ran his '70 Hemi Charger, mostly street car, down the track and got yelled at for going too fast. At over 3900lbs, and with only a lap belt, I went 11.13 at +122mph with it. It went 7.0 in the 1/8th alone and is scary stock....Bent all 10 rear wheel studs on that launch, 1.58 60ft on drag radials...He lets me drive because I got it going from 12.0's to nearly 11.0's with a few minor changes....
Re: who would you get to build a Hemi? [Re: Cape] #1095917
10/17/11 12:05 AM
10/17/11 12:05 AM
tn
robnbird Offline
robnbird  Offline
tn
I have a 426 Hemi stock bore stock stroke a mopar crate engine and not to happy with its performance if I had my time back i would have had one built. But over the winter I plan to have it modified a better combo. Everyone I have talked to say the mopar crates are a [Email]S@#t[/Email] engine. Im just wondering who you guys would have build yours? but in this combo. A 69 4 speed charger street strip but mostly strip everything else is done on the car hemi trans mcleod soft loc clutch dana 60 4.10 detroit locker and cal tracs mono leaf and slicks. the only street driving I do with the car is car shows. Im thinking of taking it to FHO. Thanks
look up Hughes machine shop and engines on here they can do what you want.
Re: who would you get to build a Hemi? [Re: robnbird] #1095918
10/17/11 12:32 AM
10/17/11 12:32 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Build it your self. I built my 572 Hemi, turned out great! I can take my time, check, recheck, and check it again. If something isnt quite right, I can have someone else look at, or ask someone who has more experience.
Re: who would you get to build a Hemi? [Re: Cape] #1095919
10/17/11 12:38 AM
10/17/11 12:38 AM
Red Deer, Alberta
bill_greenwood Offline
Red Deer, Alberta
If you're out west, I recommend you talk to Allyn Lee of ARL Racing engines. Genuine Hemi expert, plus has built a large number of record holding Stocker motors. He can build you what you're after.
Re: who would you get to build a Hemi? [Re: scatpacktom] #1095920
10/17/11 12:51 AM
10/17/11 12:51 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
Dave Dudek
Xs 2 or Westcott.
Re: who would you get to build a Hemi? [Re: scatpacktom] #1095921
10/17/11 10:01 AM
10/17/11 10:01 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Dave Dudek
I second the motion!
Check out some of Daves work here:
http://bfastracingmessageboard.runboard.com/t1593
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: who would you get to build a Hemi? [Re: Hemi_Joel] #1095922
10/17/11 11:13 AM
10/17/11 11:13 AM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
I've heard nothing but good coming from member Bob George's shop
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: who would you get to build a Hemi? [Re: Cape] #1095923
10/17/11 11:17 AM
10/17/11 11:17 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Since your in canada, tim at FHO would be an easy choice for me.
RIP Monte Smith
Re: who would you get to build a Hemi? [Re: Cape] #1095924
10/17/11 03:44 PM
10/17/11 03:44 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
What Part of Canada? We are building a 608 KB Hemi at the shop right now. We could help you out. I will send you a PM.
-Kenny
Re: who would you get to build a Hemi? [Re: CompWedgeEngines] #1095925
10/17/11 03:53 PM
10/17/11 03:53 PM
Shelton, Ct.
572_HEMI_Cuda Offline
Shelton, Ct.
FHO
Re: who would you get to build a Hemi? [Re: 572_HEMI_Cuda] #1095926
10/17/11 04:38 PM
10/17/11 04:38 PM
California
mickm Offline
mickm  Offline
California
FHO
Re: who would you get to build a Hemi? [Re: mickm] #1095927
10/17/11 08:09 PM
10/17/11 08:09 PM
Canada north shore lake Ontari...
ross Offline
ross  Offline
You won't go wrong with Tim at For Hemis Only. Give him a call 1-905-797-2459 and if you are not to far from his shop drop over and see him and look over his facilities.It would be best to call ahead. Super nice guy and an excellent engine builder.
Re: who would you get to build a Hemi? [Re: ross] #1095928
10/17/11 10:13 PM
10/17/11 10:13 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
There are alot of quality shops that can build you what you want. But I can only speak from experiance having had mine built by Tim at FHO and it is nothing short of happy! Tim stands behind his work 110% and that is something that is hard to find even from guys who are known to put out nice pieces. Give him a call you will not be sorry.
Re: who would you get to build a Hemi? [Re: SCATPK] #1095929
10/17/11 11:18 PM
10/17/11 11:18 PM
Houston,Tx.
Lee446 Online content
Lee446  Online Content
Houston,Tx.
Dave Dudek has my 528 as we speak. I expect great things!!!
Re: who would you get to build a Hemi? [Re: DragDart360] #1095930
10/18/11 12:50 AM
10/18/11 12:50 AM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
Bob George's shop
You can get burnt bad. I had my motor built and dynoed twice. Only 300 miles on the motor, and its still not right. Both by engine builders who are well known to this board.
Also thanks for all the help i recived from Hemi Fred, Bob Coomer, John Arruzza, and Mantons. Talk to some of the people on the phone. You wont hear much bad stories on here as you will by Phone conversation.
Re: who would you get to build a Hemi? [Re: MAVERICKSHEMI] #1095931
10/18/11 02:10 AM
10/18/11 02:10 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
this guy hands down. he's been known here for almost 6 years here and never a single bad word
home of the
Sox and Martin Hemi Duster
Re: who would you get to build a Hemi? [Re: HEMIFRED] #1095932
10/18/11 04:46 AM
10/18/11 04:46 AM
PA
ajcasini Offline
ajcasini  Offline
PA
Hands down, No question, BGR, for a HEMI or any other build.
Re: who would you get to build a Hemi? [Re: ajcasini] #1095933
10/18/11 06:54 AM
10/18/11 06:54 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
If you're in Canada and don't want the border hassles FHO. This side of the line, Bob George.Dave
Page 1 of 3 1 2 3
