Re: mopars and X275
[Re: n20mstr]
#1095156
10/20/11 05:46 PM
10/20/11 05:46 PM
Posts: 803 Idabel,Oklahoma
Gary Robbins
Idabel,Oklahoma
Radials are faster than slicks...its proven... They may be a lil hard to get down bad tracks, but trust me, IF you try them and have sucess....you aint going back to a slick.. You have plenty of "tools" to get your car down a track with radials...AND be faster than a slick. \
You may be right, We're sure going to give it a try...BTW which radial do you run.Already have some m/t's,but the top runners seem to prefer hoosiers.........
Re: mopars and X275
[Re: DusterMel]
#1095158
10/20/11 07:08 PM
10/20/11 07:08 PM
Posts: 4,703 On the parachute mount
n20mstr
i run Hoosier 295's they are a lot easier to get down a crappy track than the MT's they are lighter than the MT too. I have been almost identical times on both tires so in good conditions there really is no difference....
Whatever tire you use, they dont like wheelie bars...LOL Hit the bars too hard and you going to get some crazy tire shake,
You will be fine, i bet you running well on them in no time
....BAD A$$ STREET CAR.....
Re: mopars and X275
[Re: Get-X]
#1095160
10/22/11 02:37 PM
10/22/11 02:37 PM
Posts: 55 VA Beach, VA
Runnoft
VA Beach, VA
Well, to run out front nationally you have to run 4.80 1/8 miles and to do that you need to make 1500+ hp at x275 weight. BES built chevy BB's with big chief heads are getting it done, but Mopars can't run Predators or PS Hemi heads. Max effort BES 11* big chiefs flow 556 cfm @1". That is as much as my Hemi99 flows, yet the Hemi head is outlawed. Predators flow less and aren't legal either. So you're faced with trying to use a B1-MC or PSO, which is like 470 cfm.
I personally believe the smallblock n2o combo would be a better package. A good w8/9 purpose built, max effort nitrous engine could compete with SBF SBC engines. The smallblock isn't that far behind the BB in hp and gets to weigh a lot less. The sb runs @2950, can use any induction and multiple carbs and as many kits as you want. The bb runs @3250 lbs, can only run a cast manifold with a single carb and one kit only.
No Big Chief heads allowed. That was a "conventional" BBC head engine.
I was talking to the guy that built Shelly Smiths X275 SBC thats been low 4.90's - he seems to think a small block mopar with forced induction could be very competitive. The problem is there's only one or two people in the country willing to spend the $$ it takes. The mopar crowd is notoriously cheap when it comes to top shelf builds...
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116. Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
Re: mopars and X275
[Re: j.mcconnell]
#1095161
10/22/11 06:03 PM
10/22/11 06:03 PM
Posts: 4,258 Canada
WO23Coronet
Canada
Hey cold85, whats going on with your front fender there in the pic ? Is it pulling away from the body because of body twist? Fiberglass front end I'm guessing?
Re: mopars and X275
[Re: WO23Coronet]
#1095162
10/27/11 10:31 AM
10/27/11 10:31 AM
Posts: 452 nc
cold85
nc
Has a fastener underneath that i think came loose on the bottom
Re: mopars and X275
[Re: cold85]
#1095163
10/28/11 07:13 PM
10/28/11 07:13 PM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
So would a turbo R4/P5 motor in a Dragpak be legal anywhere but Georgia? What rear suspension comes in a 2011 Dragpak? Sears rules say no 4 links period! Atleast I thought that's how it read!
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: mopars and X275
[Re: W8n2DustU]
#1095169
10/29/11 08:43 AM
10/29/11 08:43 AM
Posts: 452 nc
cold85
nc
As long as. John says it is fine u are okay if he says no just put ladder bars under it.
Re: mopars and X275
[Re: bdaz smblk]
#1095170
10/30/11 03:29 AM
10/30/11 03:29 AM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
I don't see how he could say that because the class is almost all mustangs and they are 4 links
Because they come from the factory that way.
And they are not a 100% true 4-link like you would see installed after -market but they damn sure work like 1 !!!!!
Like I stated above. Some classes / rule makers have started looking the other way when it comes to some things.
If in doubt always helps to ask the Guys that actually make and write the rules.
