Page 1 of 5 1 2 3 4 5
mopars and X275 #1095072
10/15/11 08:59 PM
10/15/11 08:59 PM
San Angelo, Texas
W8n2DustU Offline OP
San Angelo, Texas
Can a Mopar be built to run up front? If so, what combo would it take? I know alot of money.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: mopars and X275 [Re: W8n2DustU] #1095073
10/15/11 09:02 PM
10/15/11 09:02 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
they consider any b1 head a conventional head....
572 b1 motor
1 big fogger
3300 lbs ladder bar
3250 leaf spring
....BAD A$$ STREET CAR.....
Re: mopars and X275 [Re: n20mstr] #1095074
10/16/11 12:04 AM
10/16/11 12:04 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
572 b1 motor
1 big fogger
3300 lbs ladder bar
3250 leaf spring
That would make a nice combo for X275. But can you get that torque hooked up on a 275?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: mopars and X275 [Re: W8n2DustU] #1095075
10/16/11 12:08 AM
10/16/11 12:08 AM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
Really need to know the Rules and how they are worded, of the Track or series or event you'll be running in. I have had an eye-opener lately at how much the rules actually vary all in the name of the same class. From track to Track and series to series or even event to event.
I have seen stock suspension written as "Bolted to stock location", which means you could use anything that would bolt in. I have also seen it say "Stock Style or Type", if they use that wording you would be stuck with a Torsion Bar front suspension.
That being said:
About your best 2 option for Stock Suspension, (which is the Norm for X275) would be.
1. a-body with cal-tracs and Tubular front suspension and K-frame that bolts into factory locations (If allowed). And Fiberglass everywhere allowed.
2. would be a 1979-1993 Mustang with a Mopar Power plant in it.
One of my co-workers has a 1983 Mustang (Chevy Powered) in this class and he's constantly nagging me to either sell him my motor or scrap my Dakota and get a Mustang to put my motor in.
Re: mopars and X275 [Re: DakFink] #1095076
10/16/11 12:21 AM
10/16/11 12:21 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
He is saying X275 it is the same rules on the whole east coast and mid west!!!!!! As also stated in the last x275 thread NO TWIN TURBOS IN X275.
Re: mopars and X275 [Re: 1967dartgt] #1095077
10/16/11 12:42 AM
10/16/11 12:42 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I'm in the bleachers watching the x275 class. There are 88 cars here in the class it's a 32 car field and #1 is 4.81 #4 is 4.88 and the bump is 5.07.
Re: mopars and X275 [Re: joshking440] #1095078
10/16/11 12:45 AM
10/16/11 12:45 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
And I just watched a leaf spring camaro go 4.60 at 170 with leaf springs and cal tracks. Just in case you don't think the cal trace will get it done.
Re: mopars and X275 [Re: W8n2DustU] #1095079
10/16/11 12:48 AM
10/16/11 12:48 AM
Get-X Offline
Get-X  Offline
Well, to run out front nationally you have to run 4.80 1/8 miles and to do that you need to make 1500+ hp at x275 weight. BES built chevy BB's with big chief heads are getting it done, but Mopars can't run Predators or PS Hemi heads. Max effort BES 11* big chiefs flow 556 cfm @1". That is as much as my Hemi99 flows, yet the Hemi head is outlawed. Predators flow less and aren't legal either. So you're faced with trying to use a B1-MC or PSO, which is like 470 cfm.
I personally believe the smallblock n2o combo would be a better package. A good w8/9 purpose built, max effort nitrous engine could compete with SBF SBC engines. The smallblock isn't that far behind the BB in hp and gets to weigh a lot less. The sb runs @2950, can use any induction and multiple carbs and as many kits as you want. The bb runs @3250 lbs, can only run a cast manifold with a single carb and one kit only.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: mopars and X275 [Re: Get-X] #1095080
10/16/11 01:25 AM
10/16/11 01:25 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
4.79 just layer down. Fastest x275 ever.
Re: mopars and X275 [Re: joshking440] #1095081
10/16/11 01:41 AM
10/16/11 01:41 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Correction. New record 4.785
FYI that was done with a conventional headed 565 BBC
Re: mopars and X275 [Re: joshking440] #1095082
10/16/11 01:48 AM
10/16/11 01:48 AM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
Chad Branson, "cold85" just went 4.94 with the turbo ford powered Dart
Re: mopars and X275 [Re: j.mcconnell] #1095083
10/16/11 02:04 AM
10/16/11 02:04 AM
Louisville, KY
Allan_G Offline
Allan_G  Offline
Louisville, KY
Where are you guys watching this? Live feed?
(FKA Racer Al back in 2000...)
Re: mopars and X275 [Re: Allan_G] #1095084
10/16/11 02:35 AM
10/16/11 02:35 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
This is the race they are talking about, it will be back on tomorrow. just click the live feed
http://dragstory.com/ws/
Re: mopars and X275 [Re: SB412DUSTER] #1095085
10/16/11 02:50 AM
10/16/11 02:50 AM
Louisville, KY
Allan_G Offline
Allan_G  Offline
Louisville, KY
Thanks much!
Re: mopars and X275 [Re: 1967dartgt] #1095086
10/16/11 04:29 AM
10/16/11 04:29 AM
DakFink Offline
DakFink  Offline
3 different tracks / events 3 different sets of rules all on 275's being the only thing that's the same. Call it 275, 8.5" or X275 fact is not all tracks or events call it the same or run the same rules except that the tire is the same. If you want to stick with the X275 designation then many tracks don't even run that class.
Same goes with Outlaw 10.5 and True 10.5.
http://king-of-the-streets.org/Street%20Race%20Rules%202012.htm
http://www.houstonoutlawracing.com/extreme_street_10.5.aspx
http://www.shakedownatetown.com/class_rules.html
That's just 3 that have been pointed out to me recently when I was looking where to put my Dakota Based on how I want to build it.
At Shakedown I could get in any 10.5 class I want as long as I could qualify. At Houston Outlaws I could only get in their ProMod class, some rule in all other 10.5 classes would put me out.
Re: mopars and X275 [Re: DakFink] #1095087
10/16/11 09:35 AM
10/16/11 09:35 AM
Baltimore,MD
lowbudget Offline
mopar addict
lowbudget  Offline
mopar addict
Baltimore,MD
I know around this area one of the front runners is Chris Evans...procharged sbf, actually theres quite a few running that combo, fox body mustang of course. But then theres also Ron Rhodes who has run in the 4s with a small block on Nos with a first gen Camaro on Nos and hes only running 23* heads and leaf springs at that. Main thing is its gonna take alot of testing to get it right and dealing with varying track conditions as the tires are tempermental
Re: mopars and X275 [Re: W8n2DustU] #1095088
10/16/11 10:15 AM
10/16/11 10:15 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
yes twin 88's sb! a bb all motor will never get the power to the little tires,bb on spray with a killer tune maybe
Re: mopars and X275 [Re: fishy340] #1095089
10/16/11 08:51 PM
10/16/11 08:51 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
Anybody alse see Chad putting on a show.Damn that is a KICKA$$ Dart!!
Re: mopars and X275 [Re: DakFink] #1095090
10/16/11 10:17 PM
10/16/11 10:17 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Only one of those events had X275(shakedown) all the others had different classes.If you want to run X275 you have to do it at one of the dozen or so tracks that run their events(MIR,CECIL,ATCO,VALDOSA,PEIDMONT,etc). If you choose to run at tracks that have different rules so be it. You need to pick a class and build your car for that class and not all these different classes you keep bringing up. If you try and build for all these seperate classes your car would probally not be real competive in any.
Re: mopars and X275 [Re: n20mstr] #1095091
10/16/11 10:28 PM
10/16/11 10:28 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Here is the tracks X275 is run at
MARCH 2011
Southern Shakedown at PBIR: 3/4 and 3/5 Ronnie Wilson – Winner(Nitrous)
Virginia Motorsports Park: 3/26 RESCHEDULED for APRIL 2
APRIL 2011
MIR: 4/1
PBIR/SHRA #2 – 4/1 and 4/2
Sunshine Heads Up Madness: 4/2
Cecil County: 4/2
Piedmont: 4/3
Rockingham Civil Wars: 4/8 – 4/10
ATCO – 4/15
MIR: 4/22
VMP: 4/23
National Trail Raceway/Unlimited Outlaws – Columbus, Ohio – 4/23
New England Dragway – 4/30
Cecil County: 4/30
MAY 2011
Capital Raceway: 5/7
Sunshine Heads Up Madness: 5/7
Piedmont: 5/14
MIR: 5/20
ATCO – 5/21
Milan, Mich: 5/21
New England Dragway: 5/21
Piedmont Ultimate Outlaws: 5/28
New England Dragway: 5/28
JUNE 2011
Cecil County: 6/4
VMP: 6/4
Sunshine Heads Up Madness: 6/4
Piedmont: 6/11
ATCO – 6/11
Milan Ultimate Outlaws: 6/11
New England Dragway – 6/12
MIR: 6/17
Milan, Mich: 6/25
JULY 2011
Cecil County: 7/2
Piedmont: 7/9
Cecil Ultimate Outlaws: 7/9
New England Dragway: 7/16
ATCO – 7/23
MIR East Coast Door Wars: 7/30
Milan, Mich: 7/30
AUGUST 2011
Cecil County: 8/6
MIR: 8/12
Piedmont: 8/13
Milan, Mich: 8/20
ATCO- 8/27
VMP: 8/27
New England Dragway: 8/27
SEPT 2011
Yellow Bullet Nationals Cecil County: 9/2 – 9/4
Piedmont: 9/10
Sunshine Heads Up Madness: 9/10
National Trail Raceway/Unlimited Outlaws – Columbus, Ohio – 9/10
MIR Ultimate Outlaws: 9/17
Rockingham Civil Wars: 9/23 – 9/25
Milan, Mich: 9/24
OCTOBER 2011
Cecil: 10/1
Milan, Mich: 10/1
Piedmont: 10/6
Piedmont: 10/8
Sunshine Heads Up Madness: 10/8
VMP: 10/8
SGMP – 10/14 – 10/16 Radial Revolution “No Mercy”
New England Dragway: 10/15
ATCO – 10/22
BMP – 10/21 – 10/23 ODRC
NOV 2011
MIR – 11/5 and 11/6 World Cup 1/4 mile
Sunshine Heads Up Madness: 11/19
DEC 2011
Snowbird Nationals Bradenton – 12/2 thru 12/4
