1969 Charger - Original spare ? #1095006
10/15/11 06:13 PM
10/15/11 06:13 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Supposed to be the original spare out of a 1969 Charger R/T.
Is it ?
If it is , this is the 1st I've seen of a Firestone in a B-body.
Re: 1969 Charger - Original spare ? [Re: gtx6970] #1095007
10/15/11 06:14 PM
10/15/11 06:14 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
2
Re: 1969 Charger - Original spare ? [Re: gtx6970] #1095008
10/15/11 06:15 PM
10/15/11 06:15 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
3
Re: 1969 Charger - Original spare ? [Re: gtx6970] #1095009
10/15/11 06:16 PM
10/15/11 06:16 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
last one
Re: 1969 Charger - Original spare ? [Re: gtx6970] #1095010
10/15/11 09:39 PM
10/15/11 09:39 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
I can tell you my October '68 built '69 R/T had a Firestone F70-14 Redline as the spare. I got the 80K mile car in '82 and was so original, I doubt it was changed, but can not say 100% if it was.
I later purchased a July built 318 '69 car that had a whiteline firestone F70-14. As luck would have it, I still have that tire and the buildsheet.
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: 1969 Charger - Original spare ? [Re: gtx6970] #1095011
10/16/11 12:40 AM
10/16/11 12:40 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
I bought a 69 Charger R/T in 1986 out in Calif from the original owner. 100% original/unrestored car and it still had the brand new F70-14 Firestone Wide Oval white stripe in the trunk.
Re: 1969 Charger - Original spare ? [Re: hemi70se] #1095012
10/16/11 11:20 AM
10/16/11 11:20 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks fellas,
I've seen Firestones in A-bodies but this was the 1st ( if it's the original ) in a B-body.
Not that it matters much really, I have it dis-mounted to repaint the wheel and it's going back in the trunk either way.
Re: 1969 Charger - Original spare ? [Re: gtx6970] #1095013
10/16/11 12:48 PM
10/16/11 12:48 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I have seen/heard of the F70-14 Firestone "white stripe" tires used in Chargers, this would be the first "red stripe" I've seen.
In '69 the T83 STANDARD "red stripe" & T82 "NO CHARGE" "white stripe" performance car 14" 70-series tire was of nylon cord construction. Goodyear "SPEEDWAY" & Firestone "DELUXE CHAMPION" "WIDE OVAL" fit that tire type. (these are the tires that were gone in less than 20K miles)
The T85 OPTIONAL F70-14 "red stripe" ONLY was fiberglass belted, AFAIK the Goodyear "POLYGLAS" was the only "major" tire manufacturer that had a 60 or 70-series fiberglass belted tire used as OE in '69. (huge improvement in wear & ride quality)
AFAIK The Firestone fiberglass belted "SUP-R-BELT" "WIDE OVAL" tire showed up for the '70 model year, but not on a MOPAR.
ALL OF THE REPRODUCTIONS (SPEEDWAY/POLYGLAS/DELUXE CHAMPION/WIDE OVAL/SUP-R-BELT/etc.) ARE POLYGLAS (polyester cord w/fiberglass belt) CONSTRUCTION
Re: 1969 Charger - Original spare ? [Re: 6bblgt] #1095014
10/16/11 12:59 PM
10/16/11 12:59 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Are these "B" - Hamtramck assembled cars?
I have NOT seen Firestones on a Road Runner, GTX, Super Bee, or Coronet R/T ..... so, I wonder if it was a HAMTRAMCK thing?
The a-bodies had Firestones for the STANDARD "performance" (non-fiberglass belted) D70-14 & E70-14s ..... so, I wonder if it was easier (more cost effective) to send a truck/train load of Firestones to Hamtramck & include the F70-14s.
Re: 1969 Charger - Original spare ? [Re: 6bblgt] #1095015
10/16/11 01:32 PM
10/16/11 01:32 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
by sequence # shown can you breakdown the tire code or date code?
I'll ck in the morning and see what plant code for the car this is out of
Re: 1969 Charger - Original spare ? [Re: gtx6970] #1095016
10/16/11 01:51 PM
10/16/11 01:51 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I have not seen any decode info for the pre-'71 Firestones.
000130HL is pre-'71
What is the date code on the wheel & the SPD of the car?
Re: 1969 Charger - Original spare ? [Re: 6bblgt] #1095017
10/16/11 07:43 PM
10/16/11 07:43 PM
western australia
1cuda Offline
1cuda  Offline
western australia
please keep this question going-i`d like to find out the real answer . my st loius built charger r/t on 26 august 1968 was coded u65 on buildsheet- i beleive they were firestone tires but i`m not 100% sure-we would have had the answer if the mopar guy who was the middle man between me buying the car in 2000 and sending it out to me here in west australia didn`t change the redline tires that were very worn so it could be moved. he also took out a few items before it shipped-the original spare and jack is no longer there and the am/fm radio is missing which is in the ics of before i bought the car.
it was coded w23 on buildsheet but the wheels are 68 style chrome magnum 500 wheels (no trimring) 14 inch but they had redlines on them.
all the best
frank.
Re: 1969 Charger - Original spare ? [Re: 1cuda] #1095018
10/16/11 07:47 PM
10/16/11 07:47 PM
western australia
1cuda Offline
1cuda  Offline
western australia
just noticed in galens white book it says u65 f70 15 rsw firestone on daytona.
all the best
frank
Re: 1969 Charger - Original spare ? [Re: 1cuda] #1095019
10/17/11 01:42 AM
10/17/11 01:42 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Frank, Is it a HEMI Charger R/T?
W23 in 1969 is the "RECALL" wheels & were available in 15" ONLY on b-bodies.
U65 is fiberglass belted - AFAIK - Firestone did NOT have a fiberglass belted F70-15 tire available in August '68. The correct tire for your car is F70-15 "red stripe" Goodyear Polyglas.
Re: 1969 Charger - Original spare ? [Re: 6bblgt] #1095020
10/17/11 05:25 AM
10/17/11 05:25 AM
western australia
1cuda Offline
1cuda  Offline
western australia
no-not a hemi charger-unfortunately-yes i know the w23 was a 15 inch wheel only-it is wearing the replacement 68 style magnum 500 wheels in 14 inch and they had redline tires on them that were the originals but i never got to see them as they were removed when the car had to be rolling to get it to me . so i better start looking for some goodyear redlines. thanx for the info.
all the best
frank.
Re: 1969 Charger - Original spare ? [Re: 1cuda] #1095021
10/18/11 11:22 PM
10/18/11 11:22 PM
lancaster, kentucky
grizzlygiff Offline
grizzlygiff  Offline
lancaster, kentucky
Bill, my car has an original spare, and looks identical to your pics. October 2 Hamtramck built car,RT with Magnum 14"wheels.
Re: 1969 Charger - Original spare ? [Re: grizzlygiff] #1095022
10/19/11 04:20 PM
10/19/11 04:20 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
Original spare from our old Daytona was a Firestone red line.
