Re: Six Pack Rocker Arms
[Re: JohnRR]
#1094778
10/15/11 11:22 PM
10/15/11 11:22 PM
Posts: 205 Martinsville, VA
440child
Martinsville, VA
A set of crane ductiles would work with only minimal clearancing for the rockers needed .
What heads are you going to run ?
Probably some 452's. Where did you have to clearance those rockers?
[Re: 440child]
#1094779
10/16/11 09:11 AM
10/16/11 09:11 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
This works well and you don't have to move the baffels.
[Re: 62maxwgn]
#1094780
10/16/11 09:24 AM
10/16/11 09:24 AM
Posts: 75,326 A gulag near you.
JohnRR
A gulag near you.
That's all the needs to be done, nothing needs to be done to the rockers just drill he baffles to clear the adjusters.
[Re: ahy]
#1094781
10/16/11 09:37 AM
10/16/11 09:37 AM
Posts: 176 Rome, GA
GTXX
Rome, GA
The spring load required for .55 lift will likely push a pushrod through the stamped rocker. Over about .5 lift, the OE stamped get real risky. You need a better rocker.
saw it happen with a 292/509, replaced with Crane irons and never a problem after that.
[Re: 62maxwgn]
#1094782
10/16/11 07:47 PM
10/16/11 07:47 PM
440child
Martinsville, VA
That's the ticket! I always wondered what was the interference point between the rocker & the v/c.
[Re: JohnRR]
#1094784
10/17/11 01:04 PM
10/17/11 01:04 PM
440child
Martinsville, VA
Anyone have a picture of the inside of an original max wedge valve cover considering they run a rocker that is very similar to the crane/isky ductiles ?
That's a great idea concerning the Max Wedge valve covers. I googled it and found that Mancini Racing sells the reproductions and the sales rep. said they would fit a 440. They don't have pictures on the website so that would really help.
[Re: JohnRR]
#1094785
10/17/11 04:14 PM
10/17/11 04:14 PM
62maxwgn
Blair County,PA
Don't really want to take one back off,two weeks ago I could have helped.If I remember correctly there is about 1/4" difference in the height of the baffles.Also,the original Max Wedge rockers were not a true 1.5 ratio,more like 1.4,don't know if that would have any bearing on clearance.
[Re: 70Sbird]
#1094788
10/18/11 12:15 PM
10/18/11 12:15 PM
JohnRR
A gulag near you.
just one more note on the MP stamped rockers, I bought a set this year, MP#P4529743 for my 440 stroker, power on the dyno was low so we measured true valve lift, The rockers were actually closer to a 1.3:1 ratio, making what should have been a warm street cam act like a grain truck/RV cam, just something to be aware of and check!
YIKES ... but then again yet another QUALITY part from MP ...
[Re: Mr.Yuck]
#1094790
10/18/11 12:31 PM
10/18/11 12:31 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
I have crane adjustable roller rockers under my stock '70 stamped valve covers.... Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: Mr.Yuck]
#1094791
10/18/11 01:04 PM
10/18/11 01:04 PM
JohnRR
A gulag near you.
no such thing as a six-pack rocker arm.
The rocker arms used on the 69 440 six pack were HD units and referred to ... I think ... as 6 pak rocker arms ...
[Re: JohnRR]
#1094792
10/18/11 01:47 PM
10/18/11 01:47 PM
62maxwgn
Blair County,PA
You don't have to think John!
[Re: DPelletier]
#1094793
10/18/11 02:00 PM
10/18/11 02:00 PM
62maxwgn
Blair County,PA
Dave,I have Isky rockers and I had to modify the baffles for clearance as shown above,not for the adjuster but the other end.Guess it depends on the rocker design.
[Re: 62maxwgn]
#1094795
10/18/11 07:41 PM
10/18/11 07:41 PM
JohnRR
A gulag near you.
I would have thought that clearance was for the adjuster , I learn something new from you Bill all the time ...
