Well I know in my case, reverse would take a lot of revving to get "kinda" going like it was slipping bad, which... it was. The reverse band was shot in my 727. A different time it was very slow to shift in between gears, and the clutches were shot. I think any of these sort of problems you should be able to tell by looking in the tranny pan/fluid for excess metallic flakes/debris or a burnt smell from the fluid. I didn't burn the fluid when reverse went out but it sucked having to roll backwards and hope I was on a hill
, forward was still perfect but I put in new Alto Red clutches and Koleen steels anyway
. Good luck!
