Page 2 of 3 1 2 3
Re: Here we go again. Clean up isle 3 [Re: dvw] #1094518
10/16/11 03:56 AM
10/16/11 03:56 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
First of all I feel your pain. I'm glad the car is repairable. The video looked liked it kicked a rod? Can you comment on your fire system? It looked like it knocked it down only to have it come back.
Doug
I'm kinda curious here, too, Jimmy - what type system you had and how it worked, or failed. I was under the impression that the gas systems work well in the cabin, due to low cleanup and the gas stays in the cabin, where the foam setups are more for the underhood areas where the foam sticks where it's sprayed and keeps cooling the area - it doesn't get blown away while the car is slowing down like I would think a gas system could.
So, your thoughts on this and what happened, or didn't happen, would be appreciated.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Here we go again. Clean up isle 3 [Re: Evil Spirit] #1094519
10/16/11 07:16 AM
10/16/11 07:16 AM
Orlando Florida
blown572dart Offline OP
Orlando Florida
After having the car out of the trailer and starting to clean it up I will say the system did it's job and did it well.
It was an oil and alcohol fire it was out for the most part,then started up again. We are going to add 2 to 3 more nozzels under the hood with the system we are using you can run 6. We have what the rules call for which is 3. The plan will be to add at a min 2 at the fire wall in the engine compartment.
I am happy with the way it functioned, driver came out okay and most of the car is in good shape. Looking at the pictures you can see it never burned the paint on all of tubing.
Jimmy
Re: Here we go again. Clean up isle 3 [Re: blown572dart] #1094520
10/16/11 10:26 AM
10/16/11 10:26 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Jimmy
What type of material did your system spray?
Doug
Re: Here we go again. Clean up isle 3 [Re: dvw] #1094521
10/16/11 11:20 AM
10/16/11 11:20 AM
Orlando Florida
Orlando Florida
FE 36
Re: Here we go again. Clean up isle 3 [Re: blown572dart] #1094522
10/16/11 02:35 PM
10/16/11 02:35 PM
Ohio
3404 Offline
3404  Offline
Ohio
Time to get myself a fire extinguisher system...
Re: Here we go again. Clean up isle 3 [Re: MoparBilly] #1094523
10/16/11 04:14 PM
10/16/11 04:14 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Thank's for forever removing any desire I may have entertained to build such a vehicle!!!!
HA! I know it. And it's not about the car so much even. I just dont want to get hurt.
Re: Here we go again. Clean up isle 3 [Re: POS Dakota] #1094524
10/16/11 05:46 PM
10/16/11 05:46 PM
Orlando Florida
Orlando Florida
ROLMMFAO
Re: Here we go again. Clean up isle 3 [Re: B Dartman] #1094525
10/16/11 11:50 PM
10/16/11 11:50 PM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
Whether you rebuild or walk away; so few if any have ever built as wild a Mopar A-Body as yourself and the A-Body world is thankful to have witnessed and/or experienced it!! Here's to hope that the dart is wrenched back to health some day soon.
As a fellow A body owner I agree with this, well said. I told the wife when my car grows up it wants to be like your car. The wickedest A body there ever was!
How bad is the metal, can it be cleaned and repainted or are you looking at a front half?
Re: Here we go again. Clean up isle 3 [Re: 10sec440] #1094526
10/17/11 08:37 AM
10/17/11 08:37 AM
Orlando Florida
Orlando Florida
It will be cleaned and repainted.
Re: Here we go again. Clean up isle 3 [Re: blown572dart] #1094527
10/17/11 09:35 AM
10/17/11 09:35 AM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Blows bigtime
But Im sure U will come
back better n FASTER
Re: Here we go again. Clean up isle 3 [Re: B1KILLER] #1094528
10/28/11 11:57 AM
10/28/11 11:57 AM
Orlando Florida
Orlando Florida
Cleaning up nicely. Should have it primed and painted by next wekend.
From this mess^^^^^^^ to >>>>>>>>>>>>>
Still have some sanding to do but it looks much better already
Re: Here we go again. Clean up isle 3 [Re: blown572dart] #1094529
10/28/11 12:04 PM
10/28/11 12:04 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Looking good.
How bad is the block?
Wish I was close enough to help
Re: Here we go again. Clean up isle 3 [Re: FastmOp] #1094530
10/28/11 12:09 PM
10/28/11 12:09 PM
Orlando Florida
Orlando Florida
Looking good.
Block is ok.
Thanks for the offer
Re: Here we go again. Clean up isle 3 ** IT'S CLEAN** [Re: blown572dart] #1094531
11/06/11 05:40 PM
11/06/11 05:40 PM
Orlando Florida
Orlando Florida
Re: Here we go again. Clean up isle 3 ** IT'S CLEAN** [Re: blown572dart] #1094532
11/06/11 05:51 PM
11/06/11 05:51 PM
Lehigh Acres, Florida
rickstershemi Offline
What happened to the "stock" front frame aquare tube rails.....did they melt away
Rickster
Re: Here we go again. Clean up isle 3 ** IT'S CLEAN** [Re: rickstershemi] #1094533
11/06/11 05:56 PM
11/06/11 05:56 PM
Orlando Florida
Orlando Florida
No had to take them off becuase of the lines that run inside them. They will go back on shortly.
Re: Here we go again. Clean up isle 3 ** IT'S CLEAN** [Re: blown572dart] #1094534
11/06/11 06:41 PM
11/06/11 06:41 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Looking good again Jimmy
Once thats all painted, it will look like new again
Re: Here we go again. Clean up isle 3 ** IT'S CLEAN** [Re: mopar_mark] #1094535
11/06/11 08:38 PM
11/06/11 08:38 PM
Orlando Florida
Orlando Florida
Thanks Mark
Re: Here we go again. Clean up isle 3 ** IT'S CLEAN** [Re: blown572dart] #1094536
11/06/11 09:26 PM
11/06/11 09:26 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Thanks Mark
As Sean Connery would say; looking shcweet Moneypenny
Re: Here we go again. Clean up isle 3 ** IT'S CLEAN** [Re: mopar_mark] #1094537
12/23/11 12:45 PM
12/23/11 12:45 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Any updates? I love this car
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Page 2 of 3 1 2 3
