Re: Here we go again. Clean up isle 3
[Re: dvw]
#1094518
10/16/11 03:56 AM
10/16/11 03:56 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
First of all I feel your pain. I'm glad the car is repairable. The video looked liked it kicked a rod? Can you comment on your fire system? It looked like it knocked it down only to have it come back. Doug
I'm kinda curious here, too, Jimmy - what type system you had and how it worked, or failed. I was under the impression that the gas systems work well in the cabin, due to low cleanup and the gas stays in the cabin, where the foam setups are more for the underhood areas where the foam sticks where it's sprayed and keeps cooling the area - it doesn't get blown away while the car is slowing down like I would think a gas system could.
So, your thoughts on this and what happened, or didn't happen, would be appreciated.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: blown572dart]
#1094520
10/16/11 10:26 AM
10/16/11 10:26 AM
Posts: 9,985 MI, usa
dvw
MI, usa
After having the car out of the trailer and starting to clean it up I will say the system did it's job and did it well.
It was an oil and alcohol fire it was out for the most part,then started up again. We are going to add 2 to 3 more nozzels under the hood with the system we are using you can run 6. We have what the rules call for which is 3. The plan will be to add at a min 2 at the fire wall in the engine compartment.
I am happy with the way it functioned, driver came out okay and most of the car is in good shape. Looking at the pictures you can see it never burned the paint on all of tubing.
Jimmy
What type of material did your system spray? Doug
[Re: MoparBilly]
#1094523
10/16/11 04:14 PM
10/16/11 04:14 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
Thank's for forever removing any desire I may have entertained to build such a vehicle!!!!
HA! I know it. And it's not about the car so much even. I just dont want to get hurt.
[Re: POS Dakota]
#1094524
10/16/11 05:46 PM
10/16/11 05:46 PM
Posts: 5,067 Orlando Florida
blown572dart
Orlando Florida
ROLMMFAO
[Re: B Dartman]
#1094525
10/16/11 11:50 PM
10/16/11 11:50 PM
Posts: 1,278 Mission BC
10sec440
Mission BC
Whether you rebuild or walk away; so few if any have ever built as wild a Mopar A-Body as yourself and the A-Body world is thankful to have witnessed and/or experienced it!! Here's to hope that the dart is wrenched back to health some day soon.
As a fellow A body owner I agree with this, well said. I told the wife when my car grows up it wants to be like your car. The wickedest A body there ever was!
How bad is the metal, can it be cleaned and repainted or are you looking at a front half?
[Re: 10sec440]
#1094526
10/17/11 08:37 AM
10/17/11 08:37 AM
blown572dart
Orlando Florida
It will be cleaned and repainted.
[Re: FastmOp]
#1094530
10/28/11 12:09 PM
10/28/11 12:09 PM
blown572dart
Orlando Florida
Looking good. How bad is the block? Wish I was close enough to help
Block is ok.
Thanks for the offer
