Re: Door removeal on e-body
[Re: bri440]
#1094178
10/14/11 11:29 AM
10/14/11 11:29 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Try a floor jack with a 2x4 on the pad, the best ones are the type with a groove routered out for strapping a crate....
[Re: 1_WILD_RT]
#1094179
10/14/11 02:10 PM
10/14/11 02:10 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I am not sure I understand the question. You asked how to remove a door, and the responses seem to me to be for installing the door. Not getting the plastic under the door at all. Can you install the door closed on an e-body? I use an engine hoist to hold the door in position. Used to use the floor jack with block of wood, but once I got a hoist it is much easier. By one handed do you mean alone (single handed)or you only have one hand? By your self, no problem, if one handed you should maybe inlist some help.
I have mechanical Aptitude. I can screw up anything.
