Page 1 of 3 1 2 3
64 pushbutton trans need help! #1094072
10/14/11 07:11 AM
10/14/11 07:11 AM
N.Y.
sixpacksteve Offline OP
N.Y.
i have a 64 belvedere 440 w/pushbutton trans. Can this be switched to a racing shifter on floor? without changing trans. was told no, looking for confirmation thanks
Hell Hath No Fury Like Mine
Re: 64 pushbutton trans need help! [Re: sixpacksteve] #1094073
10/14/11 09:09 AM
10/14/11 09:09 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
I was told that there was a floor shifter for racing at one time but it would be almost impossible to find. I still use the buttons on the dash and i go 9.67 and have no problems.
There is a company that has a floor shifter but it is not gated and i have seen the buttons moved to a platform on the drivers right to allow using the right hand to shift buttons.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: 64 pushbutton trans need help! [Re: sixpacksteve] #1094074
10/14/11 10:22 AM
10/14/11 10:22 AM
There was a recent thread that might help you, a VB or possibly a rooster comb change may let you use a floor shifter. Google it
Re: 64 pushbutton trans need help! [Re: RapidRobert] #1094075
10/14/11 10:30 AM
10/14/11 10:30 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I seriously doubt a valve body change would work, the old PB 727's had rear pumps the new ones don't. The problem is how it's shifted.
Best I can think of is using a floor shift from an early MoPar, such as my 65 Cuda, and modifying the action to be more race oriented.
Don't be the exception.
Re: 64 pushbutton trans need help! [Re: Supercuda] #1094076
10/14/11 11:13 AM
10/14/11 11:13 AM
Google it & find that comprehensive thread, I think it can be done
Re: 64 pushbutton trans need help! [Re: RapidRobert] #1094077
10/14/11 11:47 AM
10/14/11 11:47 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
The 64 A-100's used a shifter mounted on dash but again its not gated so you could shift past where you intend and I am not sure if it has all the gear selection R N 3 2 1 that is needed park is separate.
Re: 64 pushbutton trans need help! [Re: Savoy1964] #1094078
10/14/11 11:54 AM
10/14/11 11:54 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use a newer trans (1970 model) and then added the floor shifter. But I want to go back to the buttons as they are so cool. But for now I use the B & M Pro Stick and love it. Ron
Re: 64 pushbutton trans need help! [Re: sixpacksteve] #1094079
10/14/11 12:39 PM
10/14/11 12:39 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
There is a hemi- with a home-made floor shifter ....but HERE is one that was made back-in-the-day.....
Re: 64 pushbutton trans need help! [Re: dOc !] #1094080
10/14/11 03:59 PM
10/14/11 03:59 PM
Doc I remember that pic in a magazine from way back and the article made a reference something to the effect that they pirated it from a space ship/starship enterprise garage sale something or other. It always stuck in my head and I'd forgotten about until now. I'd like to make one (prob should get a PB tranny 1st)
Re: 64 pushbutton trans need help! [Re: sixpacksteve] #1094081
10/14/11 05:34 PM
10/14/11 05:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you can find a '64-'65 console shifter it can be used with any '62-'65 trans if the corresponding console/column shift valve body is used.
Re: 64 pushbutton trans need help! [Re: John_Kunkel] #1094082
10/14/11 06:15 PM
10/14/11 06:15 PM
I knew it could be done
Re: 64 pushbutton trans need help! [Re: RapidRobert] #1094083
10/14/11 08:07 PM
10/14/11 08:07 PM
N.Y.
N.Y.
i spoke with jerry stein he said same thing. find a 64-65- floor shifter or dash. but said to stick with the pushbutton setup!
Re: 64 pushbutton trans need help! [Re: sixpacksteve] #1094084
10/15/11 05:43 PM
10/15/11 05:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The PB valve body doesn't have the extra notch for Park, if you hook a PB valve body to a console/column shifter the cable core will buckle and bend when the shifter is placed in Park....every shift after that will be off because of the bent cable core.
Also, the shift cable core retaining notch is different and a console/column cable won't properly shift a PB valve body.
Re: 64 pushbutton trans need help! [Re: dOc !] #1094085
10/15/11 08:46 PM
10/15/11 08:46 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
I had one of those.. Art Carr "Nifty Shifter" -came with a B&M ball and trunion clutchflite I bought.. sold the shifter to a guy restoring a nostalgia gasser - Art told me he just used the pushbuttons out of a Dodge pickup.
Re: 64 pushbutton trans need help! [Re: John_Kunkel] #1094086
10/15/11 09:43 PM
10/15/11 09:43 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Someone might want to tell the factory floor shifter in my Cuda this news.
Re: 64 pushbutton trans need help! [Re: Supercuda] #1094087
10/15/11 09:49 PM
10/15/11 09:49 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Got pushbuttons ? Show your colors with a shirt !
Re: 64 pushbutton trans need help! [Re: Supercuda] #1094088
10/16/11 06:32 PM
10/16/11 06:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Explain.
Re: 64 pushbutton trans need help! [Re: John_Kunkel] #1094089
10/16/11 09:02 PM
10/16/11 09:02 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Explain.
I guess he didn't get the push button rfference. Just saw floor column cableshift
I have mechanical Aptitude.
I can screw up anything.
Re: 64 pushbutton trans need help! [Re: bboogieart] #1094090
10/17/11 08:13 PM
10/17/11 08:13 PM
N.Y.
N.Y.
OK car has been sitting since 1983 w/trans in car i put a 440 in it. just got it running. seems it is stuck in gear. i can push all of the buttons and they seem to work but won't go into neutral or any other gear.any ideas what to do next without ripping it apart?
Re: 64 pushbutton trans need help! [Re: sixpacksteve] #1094091
10/17/11 08:33 PM
10/17/11 08:33 PM
s. e. pa.
calrobb2000 Online content
calrobb2000  Online Content
s. e. pa.
hin
pull the pan and watch the cable and see if it is adjusted properly and that it is moving the manuel valve !
Page 1 of 3 1 2 3
