speedo on 69 charger runs 20mph faster could it be beca #1093605
10/13/11 09:45 AM
10/13/11 09:45 AM
union, tenn
tballralph Offline OP
union, tenn
I put a diff speedo in my 69 charger now it shows im going faster than i am.At 35 it shows 55 at 70 it shows 105.I did find out the mtr and trans came out of a 67 polaras could it be the gear in the trans at the cable hook up?Are the mtr and trans still basicly the same?
Re: speedo on 69 charger runs 20mph faster could it be beca [Re: tballralph] #1093606
10/13/11 09:50 AM
10/13/11 09:50 AM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Kinda confusing question. Did the old speedo read right or is this a new build? Probably the speedo pinion needs to be corrected for tire height and rear end gearing.
Scott
1969 Super Bee, 383/4 speed
Re: speedo on 69 charger runs 20mph faster could it be beca [Re: StukaJU87] #1093607
10/13/11 09:58 AM
10/13/11 09:58 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
same trans and engine but as mentioned, you need to find the right color pinion gear in the trans (where the other end of your speedo cable goes). Have to measure your tire height and your gear ratio and it will give you a tooth number/color and thats what you install...Here is a chart on the subject. I don't care for JIMs auto parts...and please do not buy from them, but it was the only chart I could find
http://www.jimsautoparts.com/transmission_parts.htm
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: speedo on 69 charger runs 20mph faster could it be beca [Re: tballralph] #1093608
10/13/11 05:32 PM
10/13/11 05:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The archives has a page on the subject with current part numbers that might still be available from the dealer.
http://www.moparts.org/Tech/Archive/auto/12.html
Re: speedo on 69 charger runs 20mph faster could it be beca [Re: John_Kunkel] #1093609
10/13/11 11:38 PM
10/13/11 11:38 PM
BDW Offline
BDW  Offline
Re: speedo on 69 charger runs 20mph faster could it be beca [Re: BDW] #1093610
10/14/11 02:12 PM
10/14/11 02:12 PM
union, tenn
union, tenn
Will tire size alone make it go up to 35mph faster?But i think the trans gear(at end speedo cable)is the problem.The car has not been on hwy for over 28 years.The speedo did not work in it so i bought a cluster rebuilt and installed it and im trying to get the bugs out now.I am green so wish me luck.
Re: speedo on 69 charger runs 20mph faster could it be beca [Re: tballralph] #1093611
10/14/11 02:36 PM
10/14/11 02:36 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Your tire size and rear end gear ratio are likely BOTH different from the vehicle the trans was pulled from. This means you will need to buy the correct speedo gear for the transmission. They are easy to change, just a small plastic gear. You can probably find the right one in the moparts classifieds section, ebay, etc.
