Re: heaterbox install -68 a-body?
[Re: sshemi]
#1093244
10/12/11 07:31 PM
10/12/11 07:31 PM
RapidRobert
Are you talking about the door(s) that swing/hinge on the vertical rod that you set in place before you fit the 2 housing halves together
[Re: sshemi]
#1093246
10/13/11 10:22 AM
10/13/11 10:22 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
Sorry should have been more clear. I mean the plates for the four studs on the fire wall
The non flat one I am pretty sure is on the engine compartment side .
[Re: JohnRR]
#1093248
10/13/11 11:44 AM
10/13/11 11:44 AM
Posts: 2,128 sweden
sshemi
sweden
thats what i think to from looking at pics but what about the flat one? To me the only logical place would be on the inside, to stiffen up but that wont fit the insulation (square hole)
I do think -72 looks the same
[Re: sshemi]
#1093250
10/13/11 04:45 PM
10/13/11 04:45 PM
Posts: 1,123 Seaford Delaware
JSR1485
Seaford Delaware
There is one with four studs that is attached to back of the heater box, that goes through the fire fall with the blower motor mounted, there are 4 spacer's and nuts that lock the blower motor to the 4 studs. Once you push it into the fire wall there is a black plate that has a flat side to it and you put the seal behind it and side the 1/2 wide seal over the blower motor and attach the black plate over the blower mototr and the four studs and tighten it doen with 4 1/4 20 nuts with washer attached. The only other part that hold the heater box in , is the rod that attcheds to the bottom of the vent area on the passenger side and hooks into the cowl.
Switched to the dark side...
[Re: sshemi]
#1093254
10/14/11 11:51 AM
10/14/11 11:51 AM
JSR1485
Seaford Delaware
This is the plate that goes on the out side of the firewall-engine side
[Re: JSR1485]
#1093257
10/14/11 12:08 PM
10/14/11 12:08 PM
JSR1485
Seaford Delaware
Sounds like you might have a extra plate that attches to the blower motor and that you will need. The 4 studs are attched to the heater box housing and the flat plate attachs to the front of the blower motor once you remove the cage.
