New best! finally #1093210
10/12/11 01:42 PM
10/12/11 01:42 PM
Corvallis,OR
540CUDA Offline OP
super street
540CUDA  Offline OP
super street
Corvallis,OR
I got to work on the car and finally get it done for some passes at Woodburn last weekend. First pass it ran a 9.62 @ 142.92 foot braking and short shifting with 11psi in the 33x17 stiff sidewall slicks. Next run 9.75 @131? and running bad. I found that the front air cleaner was shifted back and was covering the boosters, everything else looked fine so I put the steel filter lids back on. Put slicks at 8psi, and made another run = 9.42@ 142.92 (yes-same MPH). 3rd pass,rear QA1's up from 6 clicks to 7, slicks at 7 psi, raise shift point from 7200 to 7500 = 9.37@143.15mph with a 1.30 sixty foot time. The car was running great but some bent ladder bar brackets ended my day with a car sitting crooked. I can only blame myself for not bracing them enough.
I didnt do any jet changes or move the timing, so I feel like theres some left in it. Heres the combo; Porter Racing Head Mega-540, Indy-1s w/2.25 intakes 360cfm. Comp Roller 281/292 .727"/.706" 112ls 108clIndy t-ram,1050's. Sorry no vids. I'll post a pic of the car as soon as I can.
ATI 5800 9"conv. 4.56D60 33x17GY's 3300# with driver
PRH 540,T-ram,-1's tagged and insured. 9.24et 146.13mph 1.30 60'3300#s
Re: New best! finally [Re: 540CUDA] #1093211
10/12/11 02:26 PM
10/12/11 02:26 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Sounds good can't wait to get some porting on my-1's so i can see if there's any improvement on my junk
Re: New best! finally [Re: racerx] #1093212
10/12/11 02:57 PM
10/12/11 02:57 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
sounds awesome
Re: New best! finally [Re: sixpackgut] #1093213
10/12/11 03:26 PM
10/12/11 03:26 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
Nice runs, brace it up and get back out there.
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: New best! finally [Re: sixpackgut] #1093214
10/12/11 03:26 PM
10/12/11 03:26 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Way to go
Re: New best! finally [Re: 540CUDA] #1093215
10/13/11 08:17 AM
10/13/11 08:17 AM
gregsdart Offline
gregsdart  Offline
Nice! What is the elevation out there?
Re: New best! finally [Re: 540CUDA] #1093216
10/13/11 08:20 AM
10/13/11 08:20 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
that's movin' out
Coming soon!!!!
Re: New best! finally [Re: 540CUDA] #1093217
10/13/11 08:35 AM
10/13/11 08:35 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I noticed you're running a T/R. Any pics of it in situ? Would like to run one myself someday
Re: New best! finally [Re: 540CUDA] #1093218
10/13/11 08:37 AM
10/13/11 08:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Nice runs.... congrats on the new best.... I braced
my ladder bar bracket on my Rampage mainly due to
using a lateral link... that puts a lot of side load
on the brackets(right side)
Re: New best! finally [Re: MR_P_BODY] #1093219
10/13/11 01:26 PM
10/13/11 01:26 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Congrats on the new best. Ron
Re: New best! finally [Re: 383man] #1093220
10/13/11 01:58 PM
10/13/11 01:58 PM
Corvallis,OR
540CUDA Offline OP
super street
540CUDA  Offline OP
super street
Corvallis,OR
Thanks guys! I will get some pics up soon. The T-ram looks like most other pics out there, the one on Lil'demon's car comes to mind. Im hoping that once the carbs are sealed by some kind of scoop,and the engine and chassis (slicks are 6 years old) get sorted out I'll be somewhere around the 9 flat/ high 8 area. That should only take a few THOUSAND dollars more, right? By the way I think the track is at 300 feet above sea level IIRC.
Re: New best! finally [Re: 540CUDA] #1093221
10/13/11 02:10 PM
10/13/11 02:10 PM
Mo.
racerx Offline
racerx  Offline
Mo.
With a 2.25 intake valve what size bore r u running?
Re: New best! finally [Re: racerx] #1093222
10/13/11 03:09 PM
10/13/11 03:09 PM
Corvallis,OR
540CUDA Offline OP
super street
540CUDA  Offline OP
super street
Corvallis,OR
4.375" bore 4.5" stroke. I guess most others prefer the opposite to get to 540ci but mine works pretty well.
Re: New best! finally [Re: gregsdart] #1093223
10/13/11 04:09 PM
10/13/11 04:09 PM
180 above mean sea level is what I was told the first time I raced there years ago(2005). I saw -153 ft below sea level indicated(with 29.92 in the Colesman window for B.P.)on my aircraft altimeter in July with 85 F air temps and 45 % humidity My Performaire showed between 2100 and 2500 FT D.A., depending on the time of day and outside weather, mroning to late afternoon
Re: New best! finally [Re: 540CUDA] #1093224
10/13/11 07:46 PM
10/13/11 07:46 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Thax. I was wonder if a 2.25 valve will clear a 4.375 bore.I'm planing on having some head work did in the near future so i can have the 2.25 intake installed
Re: New best! finally [Re: 540CUDA] #1093225
10/16/11 06:20 PM
10/16/11 06:20 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
hey Tony,
i was beginning to wonder if you were ever going to get that thing back to the track.(not that i'm really in any position to talk.....mine hasnt been raced in about 4 years )
sounds like you're starting to get it dialed in.
what was the rpm through the traps?
Re: New best! finally [Re: fast68plymouth] #1093226
10/03/12 12:57 PM
10/03/12 12:57 PM
Corvallis,OR
540CUDA Offline OP
super street
540CUDA  Offline OP
super street
Corvallis,OR
Dwayne, I cant understand why I never saw your post but Ive been meaning to call you and update you. Last Saturday it ran a 9.30 145.13 going through the traps at about 7200? I wish I had a playback tach. I found an issue with one of my carbs and decided to get them flowed prior to all those runs last year. They came back to me with 92's and I have since jetted them up to 94's. That gained me nearly 2mph. I need to get a scoop on it still and get some new slicks,thinking about some 32x16 MT's. Im just having fun getting it down the track finally. http://youtu.be/yr7hzWzcEIM
Re: New best! finally [Re: 540CUDA] #1093227
10/03/12 01:45 PM
10/03/12 01:45 PM
NC
440Jim Offline
440Jim  Offline
NC
... raised shift point from 7200 to 7500 = 9.37@143.15mph with a 1.30 sixty foot time.
Heres the combo;
Indy t-ram,1050's.
Sounds like a lot of fun.
That thing likes some RPM!
I shift my 511 CID at 6700 (light comes on, actual slightly higher). Never tried over 7000.
My heads are close to yours, maybe a touch worse. Must be that roller cam.
I am running a Comp Cams MM305S-10 solid lifter, 279/287, .693/.672" with 1.6 rockers, 110 LSA
Re: New best! finally [Re: racerx] #1093228
10/03/12 01:49 PM
10/03/12 01:49 PM
NC
440Jim Offline
440Jim  Offline
NC
I run the 2.25" intake valve in my 440-1 heads on a 4.375" bore also. I recommend checking the valve reliefs in the pistons carefully to clear the larger dia.
Re: New best! finally [Re: 540CUDA] #1093229
10/03/12 02:02 PM
10/03/12 02:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I got to work on the car and finally get it done for some passes at Woodburn last weekend. First pass it ran a 9.62 @ 142.92 foot braking and short shifting with 11psi in the 33x17 stiff sidewall slicks. Next run 9.75 @131? and running bad. I found that the front air cleaner was shifted back and was covering the boosters, everything else looked fine so I put the steel filter lids back on. Put slicks at 8psi, and made another run = 9.42@ 142.92 (yes-same MPH). 3rd pass,rear QA1's up from 6 clicks to 7, slicks at 7 psi, raise shift point from 7200 to 7500 = [Email]9.37@143.15mph[/Email] with a 1.30 sixty foot time. The car was running great but some bent ladder bar brackets ended my day with a car sitting crooked. I can only blame myself for not bracing them enough.
NICE............. Man, that puppy`s movin out...........
