New best! finally
#1093210
10/12/11 01:42 PM
10/12/11 01:42 PM
Posts: 617 Corvallis,OR
540CUDA
super street
super street
Corvallis,OR
I got to work on the car and finally get it done for some passes at Woodburn last weekend. First pass it ran a 9.62 @ 142.92 foot braking and short shifting with 11psi in the 33x17 stiff sidewall slicks. Next run 9.75 @131? and running bad. I found that the front air cleaner was shifted back and was covering the boosters, everything else looked fine so I put the steel filter lids back on. Put slicks at 8psi, and made another run = 9.42@ 142.92 (yes-same MPH). 3rd pass,rear QA1's up from 6 clicks to 7, slicks at 7 psi, raise shift point from 7200 to 7500 = 9.37@143.15mph with a 1.30 sixty foot time. The car was running great but some bent ladder bar brackets ended my day with a car sitting crooked. I can only blame myself for not bracing them enough. I didnt do any jet changes or move the timing, so I feel like theres some left in it. Heres the combo; Porter Racing Head Mega-540, Indy-1s w/2.25 intakes 360cfm. Comp Roller 281/292 .727"/.706" 112ls 108clIndy t-ram,1050's. Sorry no vids. I'll post a pic of the car as soon as I can. ATI 5800 9"conv. 4.56D60 33x17GY's 3300# with driver
PRH 540,T-ram,-1's tagged and insured. 9.24et 146.13mph 1.30 60'3300#s
Re: New best! finally
[Re: sixpackgut]
#1093213
10/12/11 03:26 PM
10/12/11 03:26 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
Nice runs, brace it up and get back out there.
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
[Re: sixpackgut]
#1093214
10/12/11 03:26 PM
10/12/11 03:26 PM
Posts: 2,937 A shed in England
Tig
A shed in England
Way to go
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: 540CUDA]
#1093217
10/13/11 08:35 AM
10/13/11 08:35 AM
Tig
A shed in England
I noticed you're running a T/R. Any pics of it in situ? Would like to run one myself someday
[Re: 540CUDA]
#1093218
10/13/11 08:37 AM
10/13/11 08:37 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Nice runs.... congrats on the new best.... I braced my ladder bar bracket on my Rampage mainly due to using a lateral link... that puts a lot of side load on the brackets(right side)
[Re: 383man]
#1093220
10/13/11 01:58 PM
10/13/11 01:58 PM
540CUDA
super street
super street
Corvallis,OR
Thanks guys! I will get some pics up soon. The T-ram looks like most other pics out there, the one on Lil'demon's car comes to mind. Im hoping that once the carbs are sealed by some kind of scoop,and the engine and chassis (slicks are 6 years old) get sorted out I'll be somewhere around the 9 flat/ high 8 area. That should only take a few THOUSAND dollars more, right? By the way I think the track is at 300 feet above sea level IIRC.
[Re: 540CUDA]
#1093224
10/13/11 07:46 PM
10/13/11 07:46 PM
Posts: 4,078 Mo.
racerx
Mo.
4.375" bore 4.5" stroke. I guess most others prefer the opposite to get to 540ci but mine works pretty well.
Thax. I was wonder if a 2.25 valve will clear a 4.375 bore.I'm planing on having some head work did in the near future so i can have the 2.25 intake installed
[Re: 540CUDA]
#1093225
10/16/11 06:20 PM
10/16/11 06:20 PM
fast68plymouth
So. Burlington, Vt.
hey Tony, i was beginning to wonder if you were ever going to get that thing back to the track.(not that i'm really in any position to talk.....mine hasnt been raced in about 4 years ) sounds like you're starting to get it dialed in. what was the rpm through the traps?
[Re: fast68plymouth]
#1093226
10/03/12 12:57 PM
10/03/12 12:57 PM
540CUDA
super street
super street
Corvallis,OR
Dwayne, I cant understand why I never saw your post but Ive been meaning to call you and update you. Last Saturday it ran a 9.30 145.13 going through the traps at about 7200? I wish I had a playback tach. I found an issue with one of my carbs and decided to get them flowed prior to all those runs last year. They came back to me with 92's and I have since jetted them up to 94's. That gained me nearly 2mph. I need to get a scoop on it still and get some new slicks,thinking about some 32x16 MT's. Im just having fun getting it down the track finally. http://youtu.be/yr7hzWzcEIM
[Re: 540CUDA]
#1093227
10/03/12 01:45 PM
10/03/12 01:45 PM
Posts: 16,932 NC
440Jim
NC
... raised shift point from 7200 to 7500 = 9.37@143.15mph with a 1.30 sixty foot time.
Heres the combo; Porter Racing Head Mega-540, Indy-1s w/2.25 intakes 360cfm. Comp Roller 281/292 .727"/.706" 112ls 108cl Indy t-ram,1050's. ATI 5800 9"conv. 4.56D60 33x17GY's 3300# with driver
Sounds like a lot of fun. That thing likes some RPM! I shift my 511 CID at 6700 (light comes on, actual slightly higher). Never tried over 7000. My heads are close to yours, maybe a touch worse. Must be that roller cam. I am running a Comp Cams MM305S-10 solid lifter, 279/287, .693/.672" with 1.6 rockers, 110 LSA
[Re: racerx]
#1093228
10/03/12 01:49 PM
10/03/12 01:49 PM
Posts: 16,932 NC
440Jim
NC
I run the 2.25" intake valve in my 440-1 heads on a 4.375" bore also. I recommend checking the valve reliefs in the pistons carefully to clear the larger dia.
[Re: 540CUDA]
#1093229
10/03/12 02:02 PM
10/03/12 02:02 PM
Thumperdart
State of confusion
I got to work on the car and finally get it done for some passes at Woodburn last weekend. First pass it ran a 9.62 @ 142.92 foot braking and short shifting with 11psi in the 33x17 stiff sidewall slicks. Next run 9.75 @131? and running bad. I found that the front air cleaner was shifted back and was covering the boosters, everything else looked fine so I put the steel filter lids back on. Put slicks at 8psi, and made another run = 9.42@ 142.92 (yes-same MPH). 3rd pass,rear QA1's up from 6 clicks to 7, slicks at 7 psi, raise shift point from 7200 to 7500 = [Email]9.37@143.15mph[/Email] with a 1.30 sixty foot time. The car was running great but some bent ladder bar brackets ended my day with a car sitting crooked. I can only blame myself for not bracing them enough. I didnt do any jet changes or move the timing, so I feel like theres some left in it. Heres the combo; Porter Racing Head Mega-540, Indy-1s w/2.25 intakes 360cfm. Comp Roller 281/292 .727"/.706" 112ls 108clIndy t-ram,1050's. Sorry no vids. I'll post a pic of the car as soon as I can. ATI 5800 9"conv. 4.56D60 33x17GY's 3300# with driver
NICE............. Man, that puppy`s movin out...........
