Voltage Regulator Q's?
#1093116
10/12/11 10:37 AM
10/12/11 10:37 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
I swapped regulators on my '79 van. The old one had the headlights flaring up bright.
I popped it off the fire wall and swapped on a used one.
Does it need to be grounded? The battery was pretty dead this morning. I jumped it and checked the voltage. It wasn't charging. I have it hanging out in case I need to swap on a new one.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Voltage Regulator Q's?
[Re: Rug_Trucker]
#1093118
10/12/11 10:42 AM
10/12/11 10:42 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
They have to be grounded.Rocky
Chrysler Firepower
[Re: therocks]
#1093120
10/12/11 10:47 AM
10/12/11 10:47 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I hope you put that battery on a battery charger. Charging a dead bettery in the car can play havoc with you charging system.
I have mechanical Aptitude. I can screw up anything.
[Re: Rug_Trucker]
#1093123
10/12/11 11:58 PM
10/12/11 11:58 PM
Posts: 5,447 So Cal
Sinitro
So Cal
Grind away the coating on the back of the voltage regulator, this must be grounded directly to the case to the car chassis. The OE Mopar regulators are powdered-coated and/or painted on the back side preventing a solid ground connection.
Just my $0.02.. ![](/ubbthreads/images/graemlins/wink.gif)
[Re: Rug_Trucker]
#1093125
10/14/11 11:37 PM
10/14/11 11:37 PM
Posts: 5,447 So Cal
Sinitro
So Cal
Shiny chrome.
Chrome like other finishes is not the optimum conductor. Still best to take it down to the basic surface (copper) as a solid connection to chassis ground is pertinent for proper VR operation...
