Re: 360 head gasket problem
[Re: rbstroker]
#1091915
10/10/11 08:22 AM
10/10/11 08:22 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I believe the LA blocks do have head bolts that go into water.
but my Magnum 360 I don't think it had any that did. I looked at all the holes and didn't see any that were open on the bottom, so either they're all closed off from water, or they were plugged up with crud!
**Photobucket sucks**
[Re: KY Charger]
#1091918
10/10/11 09:31 AM
10/10/11 09:31 AM
RapidRobert
Murphy's law is no fun to deal with & luckily it dont happen regularly but when it does.... I hope you luck out that it'd not from a nearby coolant hole
[Re: KY Charger]
#1091919
10/10/11 09:43 AM
10/10/11 09:43 AM
Posts: 8,140 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
It has the ARP head studs, so I should be able to pull them out one at a time and put the thread sealant on and keep my fingers crossed but with the luck I've been having with the motor I might want to cross my toes also .
should to be torqued in steps/sequence but try it
[Re: UCUDANT]
#1091920
10/10/11 09:54 AM
10/10/11 09:54 AM
Posts: 15,487 Florida
scratchnfotraction
IIRC,all the head bolt holes in a SB are blind and in no water jackets just tore down my 318 and all were dry or oily no water sounds like something is not torqued down correctly,or the high comp ratio is blowing the gasket seal. dont head studs need to be torqued to different specs?
