Duster Door Rattle Cure? #109174
08/23/08 12:08 PM
08/23/08 12:08 PM
N. Ontario, Canada
John_M Offline OP
John_M  Offline OP
N. Ontario, Canada
I have a '69 Dart and when you shut the doors it makes a nice heavy thud or clunk sound. Not sure if that's a good description but it sounds solid and heavy when you shut a door.
On the other hand when I shut the door on the 74 Duster it rattles like the window hardware is loose. Is there a product available that will tighten these doors up inside? Maybe a spray insulation that I could coat the inside of the door panel with?
Any suggestions would be appreciated. Thanks.
Re: Duster Door Rattle Cure? [Re: John_M] #109175
08/23/08 12:19 PM
08/23/08 12:19 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Sounds like you need to adjust (or replace) the felt covered door glass guides at the top of the door.
Re: Duster Door Rattle Cure? [Re: In_The_Pink] #109176
08/23/08 01:20 PM
08/23/08 01:20 PM
N. Ontario, Canada
John_M Offline OP
John_M  Offline OP
N. Ontario, Canada
Ok I'll check those. If they are warn will it be noisier closing the door when the window is up or when it is down? Thanks.
Re: Duster Door Rattle Cure? [Re: John_M] #109177
08/23/08 02:26 PM
08/23/08 02:26 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
My passenger side rattles only when window is down.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Duster Door Rattle Cure? [Re: MY340] #109178
08/23/08 02:29 PM
08/23/08 02:29 PM
Nebraska
71blueduster Offline
super street
super street
Nebraska
I know the seals on the top of the doors on my Duster are worn out and need replaced. When the windows are all the way down, they rattle if I'm driving and when I close the door. It they are rolled up about an inch, then they don't rattle.
Re: Duster Door Rattle Cure? [Re: 71blueduster] #109179
08/24/08 10:55 AM
08/24/08 10:55 AM
N. Ontario, Canada
John_M Offline OP
John_M  Offline OP
N. Ontario, Canada
I don't notice the rattle so much when I am driving. Its more when I close the door and things seem loose in there.
Re: Duster Door Rattle Cure? [Re: John_M] #109180
08/24/08 11:57 AM
08/24/08 11:57 AM
littlestown pa
dustpan man Offline
dustpan man  Offline
littlestown pa
if there worn replace them or it well scrach the window i did that
Re: Duster Door Rattle Cure? [Re: John_M] #109181
08/24/08 11:57 AM
08/24/08 11:57 AM
PA
noplanb Offline
noplanb  Offline
PA
Folks bought a 71 Demon new back in the day, passenger door rattled something terrible and window was floppy rolled up. We took the door apart and found the rear guide and all the hardware lying at the bottom, guess the line rolled pretty fast back then.
If your Duster is like my Cuda, there's a bracket (part of the door frame) up front with a captive nut. That nut rattled when I closed the door, even after the door was gutted and the screw was torqued down. Car's at the body shop, haven't figured out what to do about it yet. Might be worth a look.
remember when you said honey, some day that car is gonna look so good in front of our house
