Page 2 of 9 1 2 3 4 5 6 7 8 9
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: cudaize] #1090926
10/16/11 07:27 PM
10/16/11 07:27 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
I haven't documented all the parts on the engine of my car but here are some pictures from when I pulled it out back around 1990.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: cudaize] #1090927
10/16/11 07:35 PM
10/16/11 07:35 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
Here are some components that I have documented.
Alternator: 3438172 dated 50 70
Starter: 2875560 date 7 1
Idle Solenoid: DR1114429 (round head)
Carb: was changed to a 6139
Fuel pump: replaced
right side rocker arm cover does not have the large wire clip that some of the early cars did.
Mike Afflerbach
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: cudaize] #1090928
10/16/11 11:15 PM
10/16/11 11:15 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Scott, this is the best thread in a long time! Would you want any 69 info posted here? I am restoring a 340S fastback 4 speed and there is an original owner 69 340s 4 speed convertible w-factory air who lurks on here. Other than the lower rad hose, fanbelts, radiator, negative battery cable, plug wires, alternator and carb, mine was unmolested right down to the heat shield and all A/C stuff still intact.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: RoadRunnerJD] #1090929
10/17/11 12:22 AM
10/17/11 12:22 AM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
Absalutely! Any year 340 is fair game on this thread, the more original details the better. It's a HUGE jigsaw puzzle at this point, every little piece helps put the big picture together.
* I discovered that most of the hoses that were on my complete 71 engine above are the originals, most stamps are still readable so I'll be posting pics.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: bremotorsports] #1090930
10/17/11 07:03 PM
10/17/11 07:03 PM
Warrenton, VA
Warrenton, VA
69 340 Plymouth Barracuda 340S fastback
11/13/11 ADDED MORE TRANS INFO....
Some of the casting numbers and stamped numbers were hard to read but I believe these to be correct after close inspection.
History: North Carolina undercoated car supposedly parked since 1979
SPD: C09 Monday Dec 09, 1968
K-frame 323 8 2 Nov 30
4 Speed Trans: full vin number and below it some assembly info as follows:
PP8332692. 0155
The 2692 designates Dec 10 which is one day after the SPD
B5 B5 D6X X9 blue fire metallic with deluxe bucket seat interior
Rally dash/ tachometer
D21 4 speed (no console)
Power Steering
Manual Disc Brakes
H51 heater with A/C
Block Cast Date: 9-17-68
Block Casting ID: 2780930-340-8
Engine Assembly Stamping: EW340P26880427 (Dec 6 EAD)
Block VIN: full VIN stamped on oilpan rail pad
Oil filter adapter: 11 11 8
Bell Housing: 68 and dots in 8 of the 12 squares Aug 68
Main bearings: most stamped AT20 P21 and dated 10 68
Bearings had an oil groove in top half
#3 main had a 10 68 dated bottom and an 8 68 top
#5 had no date on bottom and 10 68 top
Rod brgs.: all marked H24 9-68
Intake Manifold: 2531915-2
Casting Date: 10 29 8
Original Engine Paint Color: turquoise
Oil Pan Design:
Stamped "394" with pan rail stiffening tabs on each corner
Valve Covers:
Passenger Side: Standard Clips (with wire trough). Short upright loom bracket in rear position.
Driver Side: Tall upright loom bracket in rear position.
No paint on wire loom insulators
Engine paint on PCV rubber grommets & PCV valve
PCV had numbers on it: 9 8
Oil fill cap: black painted
PCV Grommet: 2536926 DPCD but no Pentastar
Gaskets: cork
Carburetor: was stamped D8 with 68 part number and assumed not original to the car
Choke: Housing Stamped "45"
Ignition Coil: Stamped 2444242
Date code unreadable.
Temperature Sending Unit: it's somewhere?
Oil Pressure Sending Unit:
M8 80 ("unpainted gold bell Top for rallye Instrument Cluster)
Distributor:
Tag Stamped 2875782 big scroll letters "Prestolite" with the words Prestolite Limited under it
P/N IBS -4015 B Date Code 11A
Vacuum Advance Unit No outside marking
Water Pump Housing:
Casting 2402794 6 blade small dia. Impeller
Casting Date not legible
Fuel Filter: Not Original
Power Steering Hose:
Pressure Hose Fittings Part Number/Date Code: 2891078 95165
Hose Date Info: 340 8
Return Hose Vendor Code/Date Info: 95165
Engine Insulator Rubber Mount: discarded
Alternator: not original to car
Water Pump Pulley: no number stamp on pulley.
Cylinder Heads: "X" Castings 2531894-E
Left 11 18 8, Right 11 21 8
Thermostat Housing: 2780970 no date NW-7
Fuel Pump: 4587S
Date Code 325 8
Natural finish with no overspray. Unlit hose has a 3 prong spring clamp (not a wire clamp
Dipstick Tube andhandle: Engine color
Carb Return Spring:
Accelerator Cable Bracket and Return Spring Bracket: engine color
Spark Plug Wires: Not original
Heater Hose: not original
Radiator Hoses:
Upper: original but not legible
Lower: not original
Exhaust Manifold Castings/Dates:
2863549 11 27 8 passenger side
2863553 11 14 8
Fan Belt: (not original)
Power Steering Belt:
Fan Blade: 2863215
Fan Clutch:
Date Code
Distributor Hold Down Clamp: Copper Plated
Negative Battery Cable: not original
Ground strap completely painted engine color
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: RoadRunnerJD] #1090931
10/17/11 09:13 PM
10/17/11 09:13 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Excellent detailed post John!
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1090932
10/17/11 09:27 PM
10/17/11 09:27 PM
Warrenton, VA
Warrenton, VA
Thanks. Going over the dates made me think it must have been delivered just in time for someone who had a real special Christmas in 1969!
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: RoadRunnerJD] #1090933
10/18/11 11:07 PM
10/18/11 11:07 PM
Warrenton, VA
Warrenton, VA
I added some info regarding the trans and K-frame. Has anyone else had a trans assembly date later than the engine assembly date and SPD? I wonder if they had a reason to wait for the trans? Shortage? strike!
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: RoadRunnerJD] #1090934
10/18/11 11:27 PM
10/18/11 11:27 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
I just took a 340 4-speed factory A/C drivetrain out of a 69 Formula S convertible, I will check the date codes out when I dissemble it and post them!
JB Rhinehart, Realist
A-Body's RULE!
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: Rhinodart] #1090935
10/18/11 11:55 PM
10/18/11 11:55 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Thanks Jim....Also, could you note the finishes on the attaching hardware holding the A/C brackets, etc. onto the front of the engine, Black Oxide vs engine color, etc.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: Rhinodart] #1090936
10/19/11 06:28 AM
10/19/11 06:28 AM
Warrenton, VA
Warrenton, VA
Can you post a photo of the front of the motor with things bolted up to the water pump?
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: RoadRunnerJD] #1090937
10/19/11 10:49 AM
10/19/11 10:49 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Great thread!
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: wally426ci] #1090938
10/19/11 04:35 PM
10/19/11 04:35 PM
MD
floyd Offline
floyd  Offline
MD
Following the format from above:
71 340 Challenger
JH23H1B383559
Built 5/07/71
TX9/H6X9/V1X/V7W
4-Speed (Console)
Power Steering (Fast Ratio)
Power Disc Brakes
Block Cast Date:
TBD
Block Casting ID:
TBD
TBD
Block VIN Sequence Stamping:
1B383559
Blue
Oil Pan Design:
Stamped "294". Pan rail stiffening tabs - TBD
Power Steering Hose: (Fast Ratio)
Pressure Hose Fittings Part Number/Date Code: 2891232/091 1
Hose Date Info: 33xx-xxxxx with Yellow Stripes
Return Hose Vendor Code/Date Info: 83044/1051
Cylinder Heads:
TBD
Appears original – TBD on data
Everything else isn't original to the car.
Cool thread!
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: RoadRunnerJD] #1090939
10/21/11 10:56 PM
10/21/11 10:56 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
RoadRunnerJD posted about a 69 Barracuda 340S fastback:
"Distributor Hold Down Clamp: Copper Plated"
I have a 69 340S also with a copper plated hold down clamp. But the copper plate on my clamp originally had a black coating on top, maybe paint - not sure. I scrubbed it with a mild abrasive, and the black came off.
Can anybody discuss details about this metal finish? Is it actually black paint over copper plate, or some chemical reaction on top of the copper?
I've seen plenty of discussions about finishes like zinc plating with chromates and dichromates, and phosphating, but I've never seen a finish discussed anywhere that had copper plate on steel with something black on top.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: kentj340] #1090940
10/21/11 11:32 PM
10/21/11 11:32 PM
Warrenton, VA
Warrenton, VA
I was surprised too?? Hemi's and A12's with Prestolite dual points are not copper clad. Why is it like that on a 340?
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: cudaize] #1090941
11/05/11 01:39 PM
11/05/11 01:39 PM
Warrenton, VA
Warrenton, VA
On a 69, is the intake bypass hose to the waterpump painted?
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: RoadRunnerJD] #1090942
11/05/11 02:49 PM
11/05/11 02:49 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, all 68-73 340 4 barrel's should have a painted bypass hose
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1090943
11/05/11 03:10 PM
11/05/11 03:10 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
scott, when i picked up my 69 340 a couple of weeks ago, the guy was cool, and threw the trans in, with the deal. motor is complete except for the manifolds and fan (blewbyu somehow managed to buy from the motor.... ) and it's all there, including starter, alternator, fuel pump, carb, etc. can get you some numbers when i get it out of the trailer.
will ask the "a" body guys to post in the various forums, to see if anyone has the car for this motor, and if they do, i'd swap it for another 340. mine did turn over, and nothing seems broken/missing externally. mines going into a dakota, so the starter, intake and carb, alternator and brackets, dizzie, etc., may be available, as i wont need them. thats UNLESS someone finds the car to match the numbers, and the person actually wants it.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: Golden-Arm] #1090944
11/05/11 03:18 PM
11/05/11 03:18 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Cool beans! But trust me, you left the numbers matching car at the junk yard, 1969 was only when the block was cast, it was assembled as a 1971 engine and originally installed into that blue Demon.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1090945
11/05/11 03:19 PM
11/05/11 03:19 PM
Warrenton, VA
Warrenton, VA
No paint on your bypass but it looks like paint on the alternator bracket bolt where it goes thru the water pump. No paint on the power steering bracket bolt. Is the negative cable mounted under the the throttle return spring bracket?
