Re: Warning! Totally Anal Long Winded O.E. 340 Thread!
[Re: ScottSmith_Harms]
#1090978
11/13/13 02:36 AM
11/13/13 02:36 AM
Posts: 1,661 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Original head gasket, 69 340, P.N. 2863 493, with Pentastar.
[Re: kentj340]
#1090981
11/13/13 02:44 AM
11/13/13 02:44 AM
kentj340
Cut and Shoot, TX
Discovered that the factory installed this head gasket in 'blown' configuration. The gasket was torn at the top of one cylinder and folded back on itself.
[Re: kentj340]
#1090982
11/13/13 02:46 AM
11/13/13 02:46 AM
kentj340
Cut and Shoot, TX
It's obvious the head was tightened down on the tear, because the folded over part is compressed to the same thickness as the rest of the gasket. I had never removed that head until recently.
[Re: kentj340]
#1090984
11/13/13 02:48 AM
11/13/13 02:48 AM
kentj340
Cut and Shoot, TX
I drove it 160,000 miles and never perceived a problem - there were never any obvious symptoms. But I suppose the pressure inside the crankcase must have been too high, and maybe that explains why the exterior of the engine got so greasy.
