Page 1 of 9 1 2 3 4 5 6 7 8 9
Warning! Totally Anal Long Winded O.E. 340 Thread! #1090906
10/08/11 11:39 PM
10/08/11 11:39 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
I am continuing my quest to document as many original 340 engine details as I can. I am starting with 70-71 engines and will work on other years as the opportunities present themselves. This thread pertains to documenting known original parts that are from the same engine, correct casting numbers, part numbers, date codes, etc. I have been studying and recording as many as I can before the most original examples are no longer around for reference due to restoration or replacement parts,etc. The most complete/survivor cars offer the most complete and most accurate information but those cars are exceedingly rare so I've been breaking it down to sections (engine/trans/rear end, etc.) in hopes of gathering more good detail and date code info.
Below are the known original parts found on one particular 340 engine I recently aquired as a complete and mostly unmolested original engine parts package, I have photos of all details mentioned and others as well. I have a second even more complete example I'll be documenting and posting on as well in the next few days.
If any of you wish to duplicate my efforts by submitting similar info. of your cars/engine/trans/rear details and wish to add it to my data base I would welcome it. Please feel free to contact me, I'll help you out if you need it. I will keep your cars/parts info private if you so desire.
Thanks!
Known Original Car History Info: 1971 Dodge Challenger, 340 Automatic, A/C, and Power Steering. Low mile original car involved in a bad accident, off road and in storage for many years. Car reported to have been parted out in Virginia near Roanoke.
Block Cast Date:
7/2/1970
Block Assembly Information Stamping:
GW340P3350029
Block VIN Sequence Stamping:
1B166168
Intake Manifold Casting Date:
6/19/70
Water Neck:
Casting Number 2780 970
Original Engine Paint Color:
Orange
Oil Pan Design:
Stamped "294" without welded in pan rail stiffening tabs
Valve covers:
Large/Tall Passenger Side Wire Loom Style
Drivers Side Upright Wire Loom Stand Located In The Forward Location (As Opposed To The Rearward Position Common To AAR/TA Engines)
No Paint On Wire Loom Plastic Insulators
Engine Paint On All Rubber Grommets
Engine Paint On PCV Valve
Engine Paint on Oil Fill Cap
Gaskets Black Rubber With Engine Paint On Tabs
Exhaust Manifold Casting Dates:
PN 3418621-1 Dated 9-14-70
PN 3418623 Dated 9-10-70
Carburetor:
Thermo-Quad 4973s
Stamped Date J0
3 Piece Gasket set, Asbestos, Aluminum Spacer, Asbestos
Choke:
Large Number On Top Of Housing Can Stamped “75”
Small Digits Stamped Across Near Rod Opening Stamped BA148
Choke rod:
Stamped “489”
Idle Stop Solenoid:
DR1114429
Coil:
Part# Ink Stamp 2495531
Date Code Ink Stamping 330
Temperature sending unit:
Stamped 250
Dated 0 G
Oil Sending Unit
Stamped On Underside In Singular Digits Spaced Evenly Around The Rim 8 8 0 0
Distributor:
Tag Part# Stamping 3438517
Tag Date Stamping 360
Vacuum Advance Unit Stamping Number 3433888
Water Pump Housing:
Casting Number 2951698 09104 Cav. 3
Casting Date 10/70
Fuel Filter:
Ink Stamped 30206 3220
Power Steering Hose:
Black With Solid Red Stripe Running Full Length
Stamped Into The Steering Box End Steel Crimp 35284 211
Engine Insulator Rubber Mounts:
Passenger Side Casting Number 2536121 2833735
Casting Date 8/70
Drivers Side Is A Replacement
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1090907
10/08/11 11:58 PM
10/08/11 11:58 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
your missing the X to J head changeover controversy, so i would look for head casting dates with the letter prefix info, and the whole orange to blue engine paint thing, those are the two 340 questions that pop up a lot. also remember there are at least a couple of us with engine cast dates that are 4 months earlier than the assembly date !!
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ademon] #1090908
10/09/11 12:10 AM
10/09/11 12:10 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Noted Demon, I don't have the heads for this engine but have already asked for that info. As far as the blue vs orange engine deal, yes I'm aware of that. My effort here is not meant to set any standard, I'm just gathering information that will hopefully paint a better picture of how things (usually) were. The items lacking from the above list are only missing because this particular example didn't have any other original parts to pull date codes or other details (short of paint over spray, etc.) those have been noted in a different document.
Look at how some of the dates relate to one another in the above example; for instance, the engine was assembled September 14, 1970, and the exhaust manifolds were cast only 2 weeks prior, the carburetor was also built sometime in September, that's a pretty tight time window, yet the intake was cast all the way back in June of 1970!
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ademon] #1090909
10/09/11 12:10 AM
10/09/11 12:10 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
I have a matching numbers car that the build date was the last date of the mod year...block was cast 1-1 of the same year, whats that 7-8 month gap???? Why??
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: quick77rt ] #1090910
10/09/11 12:21 AM
10/09/11 12:21 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I can't answer that question but I think a likely scenario is that they didn't control inventory like companies do today, it wasn't first in first out, and I'm sure items were misplaced only to be redicovered later to be used when found again, etc. I'm sure they pulled inventory at random in many cases.
Your engine likely just sat around a while before getting either assembled or shipped as in Ademons case, his sat around assembled from November all the way to (April or May?) before being installed.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1090911
10/09/11 10:16 AM
10/09/11 10:16 AM
New Jersey Bada Bing
bremotorsports Offline
Scott,
Since we are both charter members of the 70-71 340 CDFA (Certified Detail Freak Association), I will provide (and post here) the info for the original engine in my 71 convertible (BS27H1B344342). Subsequently, I will also provide fastener info as well, so as to enhance the archival info for interested owners of these engines.
Bill Rolik
bremotorsports@verizon.net
www.billrolikenterprises.com
201-394-5533 Cellular
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: bremotorsports] #1090912
10/09/11 11:24 AM
10/09/11 11:24 AM
British Columbia
chrisf Online content
chrisf  Online Content
British Columbia
i like where this thread is heading
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: chrisf] #1090913
10/09/11 11:41 AM
10/09/11 11:41 AM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: 71redcuda] #1090914
10/09/11 12:15 PM
10/09/11 12:15 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
x3
If theres any info I can provide from my car, don't hesitate to ask!
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: NV69B7RR] #1090915
10/09/11 12:58 PM
10/09/11 12:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Block Cast Date:
9/28/72
?? 340 P 4127 8126
3G 139836
Blue
(Short block only)
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: quick77rt ] #1090916
10/09/11 03:52 PM
10/09/11 03:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
One possibility is that there was a problem with the casting; not enough to scrap it but enough to delay machining/assembly.
There have been multiple examples posted on this forum of wide gaps between casting dates and build dates....proof that "there ain't no rules" when discussing dates.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: John_Kunkel] #1090917
10/09/11 06:38 PM
10/09/11 06:38 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Thanks to all who posted!
Here's my next victim, just got it home, probably be a week or so before I can post the details. It's a really early 1971 engine, 4 speed engine (bell housing, etc still attached) LA plant VIN to boot. Really clean "survivorish" engine, never appart, all original paint, just a few tune up parts changed and has a replacment distributor, alternator, and is missing the choke, drivers engine mount, and starter.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1090918
10/09/11 06:40 PM
10/09/11 06:40 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
VIn
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1090919
10/09/11 06:41 PM
10/09/11 06:41 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Assembly
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: John_Kunkel] #1090920
10/09/11 07:26 PM
10/09/11 07:26 PM
71 340 Plymouth Cuda Convertible
BS27H1B344342
Built 3/31/71
FE5/H6XW/V3W/V6W
Sold Through: Karl Gould Chrysler Plymouth, Vestal, NY
Automatic (Console)
Power Steering (Fast Ratio)
Manual Drum Brakes 11 X 3/11 X 2.5
Block Cast Date:
1/20/71
Block Casting ID:
2780930-340-6
Engine Assembly Stamping:
GM340P 35100085
1B344342
Intake Manifold Stamping Date:
1/21/71 ("Hump" Style)
Intake Manifold Vacuum Plug:
6-Point Raised Hex
Blue
Oil Pan Design:
Stamped "294". No pan rail stiffening tabs.
Valve Covers:
Passenger Side: Standard Clips (No wire trough). Short upright loom bracket in rear position.
Driver Side: Tall upright loom bracket in rear position.
Engine paint on wire loom insulators, all rubber grommets, PCV valve and oil fill cap.
PCV Grommet: 2536926 Pentastar only (No DPCD)
Breather Grommet: 2946079 Pentastar only (No DPCD)
Gaskets: Rubber
Carburetor:
4973S
Stamped Date On Base: 0201
Base Gasket Assy: 3-Piece with Aluminum Spacer
Choke:
Housing Stamped "75"
Choke Rod:
Stamped "489"
Idle Stop Solenoid:
DR1114429
Ignition Coil:
Stamped 2495531
Built In USA
Date code unreadable.
Temperature Sending Unit:
250 rating
Date code B1
Oil Pressure Sending Unit:
8021 ("Green Top" unit for Std. Instrument Cluster)
Distributor:
Tag Stamped 3438517
Date Code 031
Vacuum Advance Unit Stamped 3438229 (Stamped Rating at 9.5")
Water Pump Housing:
Casting 2951698
Casting Date 10/70
Fuel Filter:
Not Original
Power Steering Hose: (Fast Ratio)
Pressure Hose Fittings Part Number/Date Code: 2891232/013 1
Hose Date Info: 3361-2170A with Yellow Stripes
Return Hose Vendor Code/Date Info: 83044/0471
Engine Insulator Rubber Mount:
Passenger Side: 2536121/2863735 2/71
Driver Side: 2536121/2863735 2/71
Alternator:
3438172
Date Code 49 70
Water Pump Pulley (2951936):
Assembly line pulley with no number stamp on pulley. NOS pulleys on hand have number. Need more samples to review.
Cylinder Heads:
"J" Castings
Thermostat Housing:
2780970 09104-13
Thermostat:
Original Dole DVP-10 185 degree
Fuel Pump:
6178S
Date Code 075 1
Natural finish with no overspray.
Dipstick Tube:
Blue
Dipstick Handle:
Black
Carb Return Spring:
Violet
Accelerator Cable Bracket and Return Spring Bracket:
Blue
Spark Plug Wires:
Not original
Heater Hose:
1/2" 2936392 90142A 0391
5/8" 860457 90142A 0361
Radiator Hoses:
Upper: 3462102
Lower: 3462165
Exhaust Manifold Castings/Dates:
3418621-3 2/2/71
3418623 1/29/71
Fan Belt:
3418943 (But not original)
Power Steering Belt:
2951984 Date Code 0481
Fan Blade:
2863216
Fan Clutch:
3462112
Date Code H12A
Distributor Hold Down Clamp:
Copper Plated
Negative Battery Cable:
Stamped 2983826 and Vendor Code 73691
No paint on cable.
Accelerator Cable Sleeve:
Appears to be green tint.
Starter Motor:
2875560
Date Code 091
DOES YOUR HEAD HURT YET?
Bill Rolik
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: bremotorsports] #1090921
10/09/11 07:38 PM
10/09/11 07:38 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, head is pounding and I'm sure it will continue. The blue engines have a TON of things I've noticed that are not the same on orange engines, I have only documented one that was original enough to rely on, it had pretty much the same detail differences as yours does. I'll post that one later. I've also tweaked my original post to add a few things I forgot your notes reminded me of a few things.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1090922
10/09/11 09:17 PM
10/09/11 09:17 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here are the specs I have so far on the engine shown above, some minor dissasembly will be required to get more numbers to fill in the blanks.
Known Original Car History Info: 1971 Dodge Demon, 340 4 Speed, Los Angeles Plant, Power Steering, Power Brakes, FC7, Car reported to have been parted out in Montana. The VIN# falls between 2 known VINs that had SPD's of November 17th and November 22nd, so best guess at the SPD of the car this came out of would be around November 17th, 1970.
Block Cast Date:
5/7/70
GW340P 3266 0517 July 07 1970 Assembly Date
1E122889
Heads:
Both are "J" heads
Bell Housing:
Casting Date May/1970
Engine Paint Over Spray Over Much Of It
5/22/70
Water Neck:
Orange
Oil Pan Design:
Valve covers:
Gaskets Cork With Engine Paint On Tabs
PN 3418621-1 Dated
PN 3418623 Dated
Carburetor:
Thermo-Quad 4972s D
Stamped Date 2960 October 23rd, 1970
Choke:
Missing
Choke rod:
Missing
Fuel Pump
Stamped Date 209 0 July 28, 1970
Idle Stop Solenoid:
DR1114429
Coil:
Missing
Stamped 250
Dated 0 F
Oil Sending Unit
Date Stamped on Hex Side 80
Distributor:
Missing
Water Pump Housing/Timming Chain Cover:
Casting Date
Fuel Filter:
Unreadable, Likely A Replacement
Fan Blade
Ink Stamped 2863215
Fan Clutch
Stamped 2863 233
Center Stamped H13A (difficult to read)
No Assembly
Missing All But End Connected To Head, Appears Factory, No Signs Of Engine Paint Over Spray
Missing Both Insulators
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1090923
10/15/11 11:43 AM
10/15/11 11:43 AM
Can anyone confirm the green tint on the barrel portion of the throttle cable on a 71 340 E-Body?
Thanks,
Bill Rolik
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: bremotorsports] #1090924
10/15/11 11:57 AM
10/15/11 11:57 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, I've seen that before. It looks like ink or paint was wiped onto it and it provided a background for a black date code ink stamp. I don't have photos of a good 340 version but this is a 71 Hemi throttle cable marked the same way. It's a sort of flat looking mint green the best I could tell.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1090925
10/16/11 08:16 PM
10/16/11 08:16 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
Here's the original cable form my 71 340 Cuda SPD 3/31/71. I can't confirm that it was green but I can't deny it wasn't. If you look the coloring on the ferrule on the cable is a different hue than on the sheath.
One thing I've notice looking at the NOS cables I have is that the ferrule was painted seperatley before it was crimped onto the the cable.
Mike Afflerbach
