Magnum 500 wheels??? #1090284
10/08/11 09:00 AM
10/08/11 09:00 AM
Pittsfield, Mass.
Russ_Davis Offline OP
Pittsfield, Mass.
What are the differences between the Mopar and Ford wheels.
Re: Magnum 500 wheels??? [Re: Russ_Davis] #1090285
10/08/11 10:52 AM
10/08/11 10:52 AM
St. John's Newfoundland
440newport Offline
440newport  Offline
I believe the Ford's had a chrome lip like the new aftermarket ones, and were available in 14's and 15's. Mopars were 14's only and generally used a trim ring.
The only difference in the new aftermarket ones is the center caps.
Re: Magnum 500 wheels??? [Re: Russ_Davis] #1090286
10/08/11 11:11 AM
10/08/11 11:11 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
68 wheels don't have a trim ring whereas 69 and later used a polished or brushed trim ring. The section under the trim ring was painted black and not chromed like the non-trim-ring versions.
Re: Magnum 500 wheels??? [Re: Russ_Davis] #1090287
10/08/11 11:20 AM
10/08/11 11:20 AM
So. Calif.
bbodybill Offline
bbodybill  Offline
So. Calif.
Ford wheels do NOT fit over the rear axle stubs...
Re: Magnum 500 wheels??? [Re: bbodybill] #1090288
10/08/11 02:58 PM
10/08/11 02:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Also, the Ford wheel use the 13/16" lug nut so the lug hole countersinks in the wheel are larger....the 3/4" Mopar nut sits too deep in the countersink.
Re: Magnum 500 wheels??? [Re: bbodybill] #1090289
10/08/11 03:02 PM
10/08/11 03:02 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Or over the 11.95" disc brake hubs.
Re: Magnum 500 wheels??? [Re: bbodybill] #1090290
10/10/11 03:00 PM
10/10/11 03:00 PM
SE Pa.
LimeliteAero Offline
SE Pa.
