Re: Where can I get a neoprene accel pump for an AVS?
[Re: Spanky]
#1089881
10/07/11 03:32 PM
10/07/11 03:32 PM
RapidRobert
OE avs? Run it for a minute on a level surface & take out the metering rods/hangar assy's & take the top off & check float level then take the AP plunger out of the air horn & push it by hand into the AP well & see if it kicks out a good squirt from the nozzle. You can run a screwdriver around the inside of the leather cup to expand it but if it's really worn then as said replace it & get the right dia cup. A good visual & go from there
[Re: Spanky]
#1089883
10/07/11 04:07 PM
10/07/11 04:07 PM
Paul_Fancsali
Check and be sure the side of the carb where the pump plunger goes is not rough or gunked up from sitting that will destroy the neoprine plunger I prefer the leather as I found they can be worked with oil to get more life out of them Forgot check the one way valve by accel pump make sue it has not gone bad
[Re: Spanky]
#1089886
10/12/11 07:11 PM
10/12/11 07:11 PM
RapidRobert
wouldn't the fuel wash the oil out of the leather in a short period of time?
yes but the oil relaxes the leather so it will conform to the bore better so it ends being reshaped before the gas washes the oil out. Are you feeling pressure (tension) build as you manually push the plunger down the bore? If so take off the AP squirter and take out the brass check valve that's under it & see if you get a squirt now EDIT I would expand the leather edge with a small screwdriver so it grips the bore better, just run it around the inside edge MORE EDIT is there a supposed to be a check ball in the floor drain of the bore? Cause there a direct passage from the bore outlet to the squirter, nothing can go wrong there unless it's totally plugged & never seen that (yet) but the brass needle under the squirter can get glued down from evaporation & block flow but you're going to take that out for a check
[Re: Spanky]
#1089888
10/12/11 07:49 PM
10/12/11 07:49 PM
RapidRobert
yes that is pretty common for the AP plunger cups to dry/shrink. Luckily new ones are cheap just gotta get the right one and they can be hard to find on occaision EDIT If this is an OE AVS which will have 3 step rods/tall pri jets you can get an Eddy strip kit (2 step/short jets) so you can play with the main metering as all OE AVS's were emission era carbs & will respond good to tweaking. Pick the performer strip kit with sizes close to what the AVS has
[Re: Spanky]
#1089889
10/12/11 07:59 PM
10/12/11 07:59 PM
Challenger 1
Cincinnati, Ohio
Thanks for the plunger/oil explanation. That makes sense to me.
I took the carb off the car a couple of months ago & the pump plunger walls were pretty smooth (polished them a little anyway with some 800 grit wetordry). I removed the squirter nozzles & the passage from the plunger chamber & seems clear & the check valve is also functioning properly.
I picked the carb up at a swap meet a few years ago and rebuilt it about 2-yrs ago. Since the plunger was left sitting dry in the carb for a couple of years before it was used, could that have caused the problem?
800 grit seems too course to me, I would be concerned using the finest Scotchbrite pad.
[Re: Challenger 1]
#1089890
10/12/11 08:30 PM
10/12/11 08:30 PM
Posts: 3,054 USA
b54406barrel
USA
Fine steel wool & blow it out well. On the plunger, personally have better luck with leather than these new 'rubber' material ones.
[Re: Spanky]
#1089893
10/12/11 11:50 PM
10/12/11 11:50 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
after you get the new plunger installed successfully, look carefully at how fast it reacts when you move the throttle (you can do this on the workbench). That is what the 3 different holes are for on the pump arm. The adjustment can also adjust the pump stroke (longer stroke, more gas), but at the same time, the plunger needs to start moving instantly when you touch the throttle. If there is a lag in the plunger movement, it will show up when the engine is running as a slight bog when you tip the throttle.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
