Vacuum lines............. #108983
08/22/08 05:11 PM
08/22/08 05:11 PM
Mechanic Falls, Maine
4BBodies Offline OP
mopar addict
4BBodies  Offline OP
mopar addict
.........I am hooking up vacuum lines, I have a '72 Thermoquad on my '73 Roadrunner. I need a solution as to where to run the purge line from the canister, there is no provision on the earlier carb. Can I block it at the canister? Is the carb vent enough? Also, which small lines are full time vacuum, I need one for my A/C and want to put a "t" in somewhere. Thanks all.
Re: Vacuum lines............. [Re: 4BBodies] #108984
08/22/08 05:59 PM
08/22/08 05:59 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
If it's to run the A/C control (vacuum operated), use manifold vacuum.
I think you'll be fine with just the carb port from the cannister.
