Re: Goin to 'da Grove tonight!!!
[Re: mjs69gts]
#1089468
10/07/11 12:08 PM
10/07/11 12:08 PM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
You just might see me there on Saturday as well.... during my overall check of the car before going, I had some throttle linkage/kick down lever issues so we didn't go - a tab on the kickdown bracket holding it in place had a slight crack which meant when hitting the gas, the entire bracket moved, making that crack stretch and get bigger and bigger and... you get the point . Got it fixed last night, new bracket fabbed up, adjusted the linkage, took it out for a short cruise, re-checked and all was good. Soooo if I don't get there this Saturday, if weather is good, it will be next Thursday - that's slicks night at 'da Grove - and the track is prepped VERY GOOD. Dave
[Re: 67dodge67]
#1089469
10/07/11 12:12 PM
10/07/11 12:12 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Good luck tomorrow! What's up w/ the MPH for the ET prediction? 97 mph to run a 6.6 1/8? 116 mph for 10.7? Thats WAY low! I know it's just a prediction, but those numbers seem way off. Does it predict that based off your chassis dyno run?
[Re: an8sec70cuda]
#1089470
10/07/11 12:19 PM
10/07/11 12:19 PM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
Good luck tomorrow!
Yah, those numbers look WAY off indeed. It's a software that comes with their mustang dyno/powerdyne computer they use. They even said those numbers are not "real world" but can give you an idea atleast... heck, I know what my 60' time is with that car which has been a consistent 1.65 but.... that was before doing some new work to it (converter, heads, roller, 950 annular) so that 60' will probably change until I figure out how it will react and run. Regardless, I was AMAZED when I saw that 10 sec time there! But.... again, thats computer generated while on their chassis dyno (pics posted).
I'll be very happy if I hit 11.30-11.20's with it as it stands now. My previous best was 11.80's.
[Re: 67dodge67]
#1089471
10/07/11 12:29 PM
10/07/11 12:29 PM
an8sec70cuda
Maybe the MPH numbers are close...that'd be fairly close to run low 11s. Hope you get what you're after! Good lookin ride you have there!
