steering column coupler #108924
08/22/08 02:52 PM
08/22/08 02:52 PM
East central Missouri
larryj Offline OP
larryj  Offline OP
Anyone know if later year steering couplers well fit a 64 shaft? My 64 shaft has been off and on by myself and others before me, that the splines in the coupler are shot. I have a new steering gear box and am afraid that trying to use the old coupler would damage the new shaft splines on the box.
Thanks in advance, Larry
Re: steering column coupler [Re: larryj] #108925
08/22/08 09:56 PM
08/22/08 09:56 PM
larryj Offline OP
larryj  Offline OP
Anyone? No one?
Re: steering column coupler [Re: larryj] #108926
08/22/08 10:03 PM
08/22/08 10:03 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Replace your coupler with a borgson u joint for around $65. 3/4 smooth with a 31 spline.
Re: steering column coupler [Re: moparpollack] #108927
08/22/08 10:28 PM
08/22/08 10:28 PM
larryj Offline OP
larryj  Offline OP
Moparpollack, where do I get one?
Re: steering column coupler [Re: larryj] #108928
10/20/08 02:16 PM
10/20/08 02:16 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Do you have a part # for this joint?
Re: steering column coupler [Re: mopowers] #108929
10/20/08 02:26 PM
10/20/08 02:26 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I was interested so I found a site, not sure what part fits your application. Does anyone know what the spline size is for a 70 b-body with manual steering?
http://72.167.214.73/index.html
Re: steering column coupler [Re: GTXKen] #108930
10/20/08 03:19 PM
10/20/08 03:19 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the later coupler will fit the splines of an older box. the problem is that the later coupler uses a spring pin to locate it and hold it in place. the spring pin won't fit the earlier shaft groove. you might need to drill and tap the later coupling for a set screw to fit into the early shafts locating groove.
Re: steering column coupler [Re: larryj] #108931
10/20/08 04:31 PM
10/20/08 04:31 PM
Kansas
64Belvedere Offline
super street
64Belvedere  Offline
super street
Kansas
I did a little "article" for the 62-65 website on rebuilding the original coupler on my '64 Belvedere.
http://www.1962to1965mopar.ornocar.org/ml-houstons-steeringcoupler.html
It's not magazine quality or anything, but might be helpful.
[image][/image]
Re: steering column coupler [Re: larryj] #108932
10/20/08 07:41 PM
10/20/08 07:41 PM
templeton,ma
coro500net Offline
coro500net  Offline
templeton,ma
Do you have power or manual steering?
