Big block oil pump distributor shaft??? #1088593
10/04/11 10:15 PM
10/04/11 10:15 PM
Frederick, MD
moparguy1967 Offline OP
Frederick, MD
My question is about the correct position to install the oil pump/ distributor shaft. I have the motor at TDC, and installed the slot in the gear parallel to the camshaft. When I put my MSD distributor, it does not point to # 1. what am I doing wrong?
Re: Big block oil pump distributor shaft??? [Re: moparguy1967] #1088594
10/04/11 10:20 PM
10/04/11 10:20 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Where does it point ?
Re: Big block oil pump distributor shaft??? [Re: moparguy1967] #1088595
10/04/11 10:23 PM
10/04/11 10:23 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
If you absolutely know its on compression of TDC of #1, who cares. Rotate your plug wires so that #1 is over where its pointed at.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Big block oil pump distributor shaft??? [Re: moparguy1967] #1088596
10/04/11 10:29 PM
10/04/11 10:29 PM
Some dizzys have a different bottom tang to top rotor phasing so one dist might be right but drop in a diff one without disturbing the inter gear clocking and the rotor will be in a different position. Just lift the inter gear/shaft & reclock it till the rotor points at #1 & you're good and not required but I like to maintain the OE factory #1 wire position in the cap as it makes it less likely to make a mistake down the line and it lets the wires nestle the neatest with the shortest lengths possible so I start #1 wire per the book then reclock the gear wherever it needs to be to achieve that routing
Re: Big block oil pump distributor shaft??? [Re: moparguy1967] #1088597
10/04/11 11:21 PM
10/04/11 11:21 PM
Cab_Burge Online work
Cab_Burge  Online Work
If the slot in the gear parellels the camshaft and it is on TDC of the firing stroke the rotor should end up pointing at around 4 O clock looking down on the ditributor from the passenger side fender I try to follow the OE way Mopar index the disrtibutors with # 1 below the front distribuotr cap holdown, positioned around 4 oclock As already siad you can make the motor run with the slot at 90 degrees to the cam as long as the firing order is starting where the distributor rotor is pointing at that place on the cap where #1 spark plug wire is when #1 is at TDC on the firing stroke I've seen B,RB and 426 Hemi motors wired a whole bunch of different ways
Re: Big block oil pump distributor shaft??? [Re: moparguy1967] #1088598
10/05/11 12:28 AM
10/05/11 12:28 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
The "correct" way is to have the engine at #1 TDC and install the distributor gear with the slot parralleling the camshaft. It won't be "absolutely" in line with the cam, but cocked slightly towards #1 cylinder. If you get it too far off parrallel, it can be hard to set the timing as the distributor advance may hit things.
