Front and Rear Window Channels. Should I blackout? #1087278
10/03/11 10:53 AM
10/03/11 10:53 AM
Tenn.
jrwoodjoe Offline OP
Tenn.
Before the front and rear windshields get installed, I just wanted to see if the channels that the glass sets in should be blacked out so the body color does not show through the glass. Does the trim hide that?
Thanks, Joe
65 Barracuda
70 Challenger
Re: Front and Rear Window Channels. Should I blackout? [Re: jrwoodjoe] #1087279
10/03/11 10:57 AM
10/03/11 10:57 AM
western australia
1cuda Offline
1cuda  Offline
western australia
yes-on my challenger vert i could clearly see the that it was flat black and brushed. not sure on the back screen but i would also say black it out.
all the best
frank
Re: Front and Rear Window Channels. Should I blackout? [Re: jrwoodjoe] #1087280
10/03/11 12:05 PM
10/03/11 12:05 PM
Ft. Worth, TX
TransAm Twins Offline
Ft. Worth, TX
Definitely black them out. I wound up pulling the windshield as there was way too much body color showing after the install. Mostly on the A pillars.
I was able to do the back light from the inside with a brush. Still have stiff neck from that.
Re: Front and Rear Window Channels. Should I blackout? [Re: TransAm Twins] #1087281
10/03/11 12:24 PM
10/03/11 12:24 PM
Tenn.
Tenn.
Thanks guys, you both mentioned brushes. What type of paint did you use?
Joe
Re: Front and Rear Window Channels. Should I blackout? [Re: jrwoodjoe] #1087282
10/03/11 06:17 PM
10/03/11 06:17 PM
Ft. Worth, TX
Ft. Worth, TX
Semi-gloss enamel.
Re: Front and Rear Window Channels. Should I blackout? [Re: TransAm Twins] #1087283
10/03/11 09:03 PM
10/03/11 09:03 PM
Ct, Oxford
340swing Offline
340swing  Offline
Ct, Oxford
not sure but i think the black brushed on stuff you see is a primer windshield installers use. The factory may have used this also so the butyl would stick. Any windshield installers chime in.
