Re: Wheel cylinder gasket....why?
[Re: HelleOnWheels]
#1087196
10/03/11 07:22 AM
10/03/11 07:22 AM
RapidRobert
helps keep road splash out. Perfect use of silicone in lieu of a gasket
[Re: dennismopar73]
#1087198
10/03/11 10:05 AM
10/03/11 10:05 AM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
well to be honest, it serve no real service!! the whole drum is open around the shoes, but if youre car is oe car show inspected , it needs those
It is? There is a lip that stops water splash from entering unless you submerge the drum. Drum brakes dont like water. This is why there is a gasket and plug for the adjuster.
I would advise using somethign to seal it.
[Re: HelleOnWheels]
#1087200
10/03/11 06:50 PM
10/03/11 06:50 PM
POS Dakota
detroit, mi
I dont have new gaskets and wanted to put the brakes back together. I will just use a small bead of silicone. My car is definitely NOT a trailer queen!!!
That's fine and will do. Adjusters freeze up too soon as it is...keep as much water out of there as you can.
I just took a set apart that was so bad I chucked the whole backplate with everything on it in one piece.
