Re: cheap 360 build, thoughts?
[Re: 340duster340]
#1087049
10/02/11 10:59 PM
10/02/11 10:59 PM
RapidRobert
cheap double roller timing chain. Forgo the pump/bearings so wont have to disturb the pan. SB street dominator intakes can be had for $75 & have 318 ports (matches your heads) and is a spread bore. No opinion on the cam. A FUNCTIONING thermoquad carb
[Re: RapidRobert]
#1087050
10/02/11 11:02 PM
10/02/11 11:02 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Pan has to come off anyways...to get replaced with a car one from the truck/motorhome one. ![](/ubbthreads/images/graemlins/wink.gif)
[Re: POS Dakota]
#1087055
10/03/11 01:04 PM
10/03/11 01:04 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
74k on a 360 is still pretty young for just a driver providing it's in good shape. I would be compelled to pull the pan and take a peek inside. I'm just crazy like that.
For sure. Check bearings.
[Re: mdwyer]
#1087058
10/03/11 04:54 PM
10/03/11 04:54 PM
Posts: 15,487 Florida
scratchnfotraction
this looks interesting
http://www.moparts.org/Tech/Archive/smallblock/8.html
I have done this with a few 360 truck engines for towing and 4x4s
last one had the #302 heads with a home pocket port with 1.88/1.60 valves
600 carb LD4B intake napa brand cam with .423/.443 lift headers with duel 2.5 pipes
worked great for a truck, same combo was even more fun in the 68Dart with a stock HS TC and 3.55sg
I say go for it ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 340duster340]
#1087062
10/04/11 12:02 AM
10/04/11 12:02 AM
Posts: 4,461 Michigan
MarkZ
Worthy
Worthy
thanks guys for the feed back now that i think of it i have the 302 swirl heads and a set of the LA360-roller block heads (i forget the casting #).
Definitely use those 360 roller block heads you have (should be a casting number ending in 308). Building a low RPM torque motor for a truck I wouldn't hesitate using 302 casting heads on a 360, but for a car it's going to seriously saddled the top end.
i only have a904's that were previously behind a 318, but I can get a weighted flex plate right?
Yes you can. I ran one the same piece for years until I stepped up to a 518 transmission.
Part #: BMM10239 http://chucker54.stores.yahoo.net/bm1.html
if possible i would like to use manifolds rather than headers. unfortunately all i have left is a set of 318 manifolds from a 74 dart.
Don't sweat it, you'll never see a difference between any of the small block manifolds on a mild motor.
http://www.moparmusclemagazine.com/techa...t/photo_17.html
[Re: MarkZ]
#1087063
10/05/11 12:01 AM
10/05/11 12:01 AM
Posts: 4,323 NY NY
340duster340
NY NY
thanks for that article!! if that is the case then i am going to use a set of a body 318 manifolds i have and sell the 273 ones.
i can't want to start putting this thing together, now just have to get rid of the parts car and dig out the motor from the back of the shop,
[Re: 340duster340]
#1087064
10/05/11 05:00 AM
10/05/11 05:00 AM
RapidRobert
318 ex manifolds wont fit on the dr side ('66 A with SB). You'd need to stay with the 273 logs or 340 HP's work in some cases as there's a tremendous stackup (variation) of tolerances in early A's. In any case the 340 HP's will fit if you shorten the manual steering coupler to 1/2 it length (still works fine). If that's the article claiming only several horse diff between mani's/headers iirc it's a misprint. headers with a good ex are going to be much better difference than that. The 273 logs will fit perfect but utilize a 2" ex pipe. No way that will give you much unless it's going to be a DD stocker
