Re: Drive line length?
[Re: stumpy]
#1086829
10/02/11 02:58 PM
10/02/11 02:58 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
I have always believed no more than one inch but at least 3/4".
That's what I was afraid of. Looks like I need a new drive line. Thanks for the reply.
[Re: screamindriver]
#1086831
10/03/11 10:29 AM
10/03/11 10:29 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
And if you've got the factory type rear trans seal with the protruding dust cover the yoke would end up almost flush with it using the 3/4 out from bottoming value.
Yep, every stocker I looked at "back in the day" had no more than 1/4" to the boot.
Rick
[Re: Cab_Burge]
#1086833
10/03/11 03:51 PM
10/03/11 03:51 PM
Junky
Wherever I am.
there are some of the trans yokes that have mor epslines in them than others also, so maybe you should look at how long yours is and go from there If it has three inches or less splines insides lengthen the driveshaft, if it is five inches long maybe you can use it
Thanks for the heads-up.
